GM Boost control solenoid
Old Jul 29, 2004 | 06:50 PM
  #31
MalibuJack's Avatar
The restrictors in the line effectively act like the MBC setting.. so as long as the result you get works, then more power to ya.. Its still acting as a bleed system since you have the stock solenoid and a Tee.. I think that with the new solenoid, and not using a bleed system but a restrictor type system, you can get the results of a standalone boost controller.. Time will tell.. I should have my parts in a few days..
on an offtopic note, with 21deg of timing, 11.8 is WAY too lean.. Even though you get no detonation, your not leaving yourself any headroom (Btw I run the same timing at higher RPM, only I am closer to 11.4afr's for the most part.. though 11.4's are tough for me to get with the stock pump with 22psi of boost and I am concerned that the pump will overheat and go lean, so I keep my boost very low until I can install the pump and injectors)
Old Aug 2, 2004 | 08:56 PM
  #32
MalibuJack's Avatar
Solenoids got here.. Forgot to order the pigtails! But I will begin fabbing everything up tomorrow, I have to pick up several T Connectors..
Old Aug 3, 2004 | 04:46 AM
  #33
bbbwrx's Avatar
I am excited to see how this turns out. I might have to fab me up the same setup (well maybe I should buy the UTEC first )
Ben
Old Aug 3, 2004 | 06:37 AM
  #34
TearItUpSports's Avatar
I found that local GM dealers usually carry the pigtail in stock. Just not the solenoid, or any air inlet temp sensors. The pigtails are about $10 more locally though than GMpartsdirect (including shipping).
On a side note, do you have a connector that will work with the stock mitsubishi wiring harness?
Old Aug 3, 2004 | 07:36 AM
  #35
MalibuJack's Avatar
Haven't found one of those yet.. But I'll be contacting mitsubishiparts at some point when I get a chance to sit down with the parts.
mrfred
Apr 21, 2013 01:17 PM
lapulapu
Sep 9, 2008 05:52 PM
sba
Apr 8, 2008 05:07 PM
Kunz
Nov 28, 2005 11:57 AM
PPI
18
Aug 25, 2005 05:34 PM
