Map Seletor
Map Seletor
Have a quick question about the map selector wiring. I see where it plugs into the utec, and has a red wire and black wire (for the extra solenoid) and a green wire and white wire. What are the latter 2 wires for? And they have a jumper for them? Where do they go?
Thanks
Thanks
If your talking about the wires that come off the switch, its the "clutch switch".. on the EVO Utec it's not necessary to hook up (I cut those wires off) because the factory ECU wiring harness actually has a clutch switch signal.
