Could some post Datalog with MAP sensor data ?
Old Sep 13, 2004 | 11:09 AM
maikonkun's Avatar
As per the title, I'd really appreciate it if anyone with the external MAP sensor could post a datalog run showing the MAP sensor data.
TIA
Old Sep 13, 2004 | 06:17 PM
MalibuJack's Avatar
I posted some logs from my runs (or at least snapshots) that show my MAP sensor.
Old Sep 13, 2004 | 09:05 PM
maikonkun's Avatar
I think I found the jpg snapshots showing plots of boost against timing etc, but I am really after the raw utec data from a third or 4th gear WOT pull.
I did a several searches and in particular on psia and psig, but the only thing i found was a short utec log you posted at :
https://www.evolutionm.net/forums/sh...ad.php?t=94938
But thanks for the reply.
Would anyone else like to post or send me a log ??
Old Sep 13, 2004 | 09:15 PM
MalibuJack's Avatar
What in particular are you looking for? calibration information? Or the difference in PSIG and PSIA? Its easy enough to build and install your own sensor that you can get this info yourself.
Old Sep 14, 2004 | 07:24 AM
maikonkun's Avatar
I am hoping someone would post a "shift 1 data log " of a 3rd or 4th gear WOT run.
In the link I referenced you posted a bit of data :
Data1
, , , ,Load,Knock, , , Mod, Mod, , Mod, WB
RPM, MAP, MAF,TPS,Site,Count, Ign#1, Inj#1, Ign, Fuel,Boost, MAF, AFR
, psig, Hz, % , , , deg , duty , deg, % ,(OL) , Hz,
2041, -8.6, 81, 12, 00, 00, +32.8, 5.0,ECU. , +0.0,ECU. , 84, 14.74
2022, -8.6, 83, 12, 00, 00, +33.0, 4.5,ECU. , +0.0,ECU. , 79, 14.61
2022, -8.6, 73, 11, 00, 00, +32.6, 3.7,ECU. , +0.0,ECU. , 72, 14.65
2004, -8.8, 67, 10, 00, 00, +31.5, 3.8,ECU. , +0.0,ECU. , 62, 14.61
1996, -9.0, 62, 10, 00, 00, +31.5, 3.7,ECU. , +0.0,ECU. , 61, 14.53
1987, -9.4, 58, 9, 00, 00, +31.5, 2.5,ECU. , +0.0,ECU. , 56, 14.58
but this is not a full run.
I talked about psig and psia, because I thought that would be the best way to find any datalogs posted to this forum which included external MAP data. Unfortunately the above snippet is the only thing I found.
I have made some runs with the 3 bar sensor, but I would like to compare to someone else's just for comparisons sake.
Any takers ?
Old Sep 14, 2004 | 10:09 AM
MalibuJack's Avatar
I think alot of the data was posted as attachments because some of it is large..
Clipse3GT
Apr 8, 2009 07:26 PM
Import Junky
Jan 2, 2009 09:28 PM
broddey
Feb 18, 2008 02:06 PM
bvdawg13
Dec 28, 2006 01:13 PM
RichJ
20
Jan 5, 2004 09:43 AM
