Getting a UTEC, but need a few answers
Old Sep 15, 2004 | 06:47 AM
areet's Avatar
Well, I searched for a while, but didn't really come up with any solid answers, so I figured it wouldn't hurt to ask. I plan on buying a UTEC, and probably getting the Tuner later, due to lack of funds. But back on topic, I figured I should buy the Map selector switch, and a MAP sensor, but which one? I've heard good alot about the GM 3-bar MAP sensor, does anyone have a part # for it? Are there any other "little things" that should be purchased and installed with the UTEC? Any advice would be greatly appreciated.
--John
*edit* I forgot to ask if an EGT sensor would be able to be connected directly to the UTEC, or that would be a function of the Tuner? Either way, which is a good Probe for installing on the #1 or #2 runner, 2" from the block, as I've heard they come in different lengths.
Old Sep 15, 2004 | 07:07 AM
areet's Avatar
Whoops, I just went through the Utec manual and found the part # for the GM 2nd-gen MAP sensor *blushes*.
Old Sep 15, 2004 | 09:06 AM
MalibuJack's Avatar
Yeah, EGT Sensor is a function of the Tuner Pro... I've been asking them to add the EGT temp onto the shift-1 data logging in a future Tuner Pro firmware upgrade (if its installed)
I think its a type-K EGT sensor btw.. shares the same molex part number (and I assume wiring is documented) in the Tuner Pro manual..
mfr122887
13
Apr 16, 2008 04:08 PM
201Motorsports
12
Sep 30, 2006 09:09 AM
EVO8LTW
Jun 11, 2005 10:36 AM
MalibuJack
Nov 18, 2004 08:18 PM
sgplancer
11
Aug 26, 2004 06:00 AM
