Gruppe-S Engineering - California [Visit Site]
EVO MR Bilsteins!!!!!!!!
Old Sep 18, 2004 | 07:38 AM
jason@NTEC's Avatar
imagine someone comparing the cheap cost of domestic vs. the more expensive quality of japan parts!! they were cheaper cause the build quality of the WS6 is cheaper.
Old Sep 18, 2004 | 08:25 AM
JustDSM's Avatar
There's two part numbers for the rear springs on the MR. I'm going to have to investigate.. On first impression the fronts are obviously different springs. Rears *could* be the same.
Old Sep 18, 2004 | 09:14 AM
RonV's Avatar
Dude, your ignorant.
Old Sep 18, 2004 | 09:44 AM
marksae's Avatar
Perhaps Mitsu used different springs for the left and right sides of the car?
Old Sep 18, 2004 | 10:28 AM
JustDSM's Avatar
Nope, they are two seperate listings for both rear springs. ????
Old Sep 18, 2004 | 10:34 AM
RonV's Avatar
Maybe one # for AYC and one without?
Old Sep 18, 2004 | 01:34 PM
Gruppe-S's Avatar
Originally Posted by EVO-Bandit
Cal,
I don’t mean hijack your thread, but I’m curious as to why these particular Bilstein shocks for the EVO are relatively much more costly than for other models. IIRC, when I upgraded to Bilstein shocks on my WS6, I paid about $360 for the entire set (2 front, 2 rear).
Is it because they are imported from Japan and / or sourced from Mitsubishi? I’m thinking that Bilstein will eventually manufacture replacement shocks for the US EVO and the cost will be closer to that of other models.
Further, do you have any information on the MR spring rates? Does the MR have different spring rates than the VIII (I’m asking this because I really don’t know)? If the MR does have different rates, wouldn’t the Bilstein dampers be valved specifically for those rates?
Thanks for your time.
Hey! these are very good questions! I also would like to know also! I will try to gather up some more info on the spring rates and why these Bilsteins cost so much compare to the off-the-shelf Bilsteins on the market.
I will keep you guys posted!
Thanks!
Cal
Old Sep 19, 2004 | 12:55 PM
BADWRX's Avatar
You are paying for specialty parts on a high performance car. Mitsu dumped a ****load of dough developing these parts, plus they are OEM, and OEM is straight expensive always.
That is my take on in anyway.
Old Sep 19, 2004 | 01:10 PM
osunick's Avatar
No they're cheaper because there are far fewer evos than trans ams (lower volume=higher cost), and the trans am has shocks, not inverted struts. An f-body has dual control arms in the front and a live axle in the rear, so there is no need for an overbuilt inverted strut performing damping and the structural work of an upper link (locating the wheel) at the same time, which is what you have with the macpherson strut on the evo (and most other cars these days). Struts aren't necessarily bad, porsche and bmw use them on the fronts of all their cars, but they are expensive in a high performance application.
Old Oct 12, 2004 | 07:49 AM
plokivos's Avatar
I believe the domestic cars are cheaper, because the cost involved in importing them, making them seperate for US spec and luxury and gas tax that gets put on the evo.
Also, the brand name reputation value makes them hold their value better.
then all that nsnguyen said.
I think those blisten shocks are great, but bit overpriced compared to some of the shocks or coilovers that's out in the market now, such as JIC and TEIN.
The shock dampening ratio is also developed in conjunction with the spring height, so I don't know how they'll act when you drop it about 2 inches...
Old Oct 12, 2004 | 08:17 AM
Eric Lyublinsky's Avatar
Yep!
Old Oct 12, 2004 | 10:11 AM
Mech_Engineer's Avatar
Do the rears come with new jounce bumpers????? Because the Bilstein damper has a different rod diameter!
BTW... Spring rates are the same as 03 and 04 model years.
Old Oct 12, 2004 | 01:12 PM
marksae's Avatar
Jounce bumpers? You mean bump stops? Do the Bilsteins rods have a larger or smaller diameter compared to stock? If larger, then you could probably just drill them out to make it fit. If it's smaller, no big deal. It just won't look as clean but will still serve its function.
Old Oct 18, 2004 | 02:01 PM
dilow's Avatar
Anyone have any new info on the springs?
Old Oct 18, 2004 | 05:27 PM
Gruppe-S's Avatar
As far as I know, the Spring rates between the MR and the GSR are the same.
