J-OnDemand – CA [Visit Site]
JDM Evo Double Din Dash
Old Jul 9, 2007 | 03:31 PM
Chukee_R's Avatar
With Orbital discontinuing their Double Din kit, are you guys able to get the trim piece from JDM Mitsu dealers?
I'm just curious to what options I have in order to use an in-dash screen.
Thanks!
Old Jul 9, 2007 | 07:02 PM
outsider's Avatar
You could get that from JoD... but you would still have the issue of where to relocate the HVAC controls too.
Old Jul 9, 2007 | 07:37 PM
Chukee_R's Avatar
I think it'd be easier to do this than create a trim piece.
Old Jul 9, 2007 | 08:11 PM
outsider's Avatar
You would still need to create a piece for the HVAC... so in the end it would probably be as much if not more than the Orbital piece.
Old Jul 10, 2007 | 03:17 PM
xX v0oDo0 Xx's Avatar
I think some of you are missing the point...This post is in reference to the trim panel, which is available in Japan...You cannot use the JDM a/c unit, so you will still need to purchase the orbital conversion kit if you want to run a double-din headunit...And order it quickly, because they will be discontinued shortly...Off-hand, I recall seeing stereo trims from Mitsubishi Japan and ColtSpeed...Contact someone over at JoD and they will be happy to help you out.
Old Jul 12, 2007 | 11:22 AM
JondemandSales's Avatar
call us anytime =)
Old Jul 17, 2007 | 05:00 PM
edzilla's Avatar
I had the combo written down somewhere, but you can use some OEM pieces from the GALANT and some other Mitsu SUV to make a working electronic HVAC. I'll see if I can dig it up somewhere.
Ed
Old Jul 24, 2007 | 04:20 PM
JondemandBrende's Avatar
i have this at home, i have the OEM bezel that is the same black grain as the dash and the ralliart overlay 2 din. i will post pics so u know what it is and will have the part number for u so u can order with us!
Old Jul 25, 2007 | 10:23 PM
sfuboy's Avatar
Wow.. please post the info once you get it JondemandBrende!
Old Jul 25, 2007 | 10:50 PM
Chukee_R's Avatar
That would be awesome.
I'm guessing this would be the same thing?
Would I have any problems if I bought the orbital double din, relocated the HVAC and got this for the trim piece around the head unit?
Old Jul 26, 2007 | 09:58 AM
This is the Ralliart 2-Din overlay bezel in CF
OEM JDM Mitsubishi 2-DIN
ill have the pic of the actual black 2 din insert tomorrow.
Old Jul 28, 2007 | 01:09 PM
OEM JDM 2-DIN in the black
Old Jul 29, 2007 | 06:31 PM
ARYEVO's Avatar
I need to get a Ralliart 2-din overlay bezel in Carbon Fiber, should I get a JDM 2-din bezel also ?
Old Jul 30, 2007 | 12:37 PM
the Ralliart piece is just an overlay for the bezel. U can get the black bezel as i have or the OEM silver look bezel. Either way u need both pieces cause the bezel attaches to the dash and the Ralliart overlay sticks on to the bezel and doesnt have clips to fit into the dash.
TxFAkuma
Feb 11, 2017 07:48 PM
ckevoxnyc
May 20, 2016 06:18 PM
bhaikalis
Feb 5, 2016 05:35 PM
racespad3
Nov 12, 2015 03:09 PM
racespad3
Nov 9, 2015 08:50 AM
