Updated Dyno Results!!
Old Oct 2, 2004 | 12:06 PM
prototypemike's Avatar
Well guys i have little problem. i changed my oil this morning and after being changed i checked the drain pan and saw that there where some metal shavings in the pan. the shavings looked like a bronze color. Also i saw that the oil was a little thin so i smelled it and it smelled like gas. So gas was also in the oil.
So i guess the question is has this ever happened to anyone? I believe that the reason for the Gas is because before getting the car tuned i was running very rich and because of that i think thats what the problem was. Maybe now that the car has been tuned and the oil has been changed maybe it will stop the gas from mixing with the oil.
Now as for the shavings, is that do to Rod bearings and is the motor on it's way out the door?
P.S.- The oil that i have been using is Castol HD 30 which is straight 30 weight.
Please Help!!!!!
