Car running like crap...
Originally Posted by mcbrown35
Problem is my car is still running like crap! I'm about to yank the stage 2 and just run stage 1. Either the leak is back around the injector with the new seals, or there is another problem. At WOT the car bogs down and does not accelerate. If i keep half throttle I can accelerate easily past 100mph...as soon as I hit WOT, nothing...
As far as forced induction goes... if you have an inspection on the car it will fail due to that modification anyway. Whether or not you have proper idles or no codes that part is not considered legal unless it is allowed by the state. As far as i know non of the states allow the adding of a turbo to the car legally. Some just don't have those checks on the cars and they get by. I'm not saying this as fact just stating that going turbo on a non turbo car usually steps you out of being legal unless there is some kind of Carb cert for it.
On a lighter note keep searching for the leaks... they must be there. If you pressurize the system to full boost pressure and find no leaks then you need to look at some other things like MAS modification setup... fuel system pressure... and maybe even piggy install. Once their out of the way and all good its time to get RRM involved.
I'll pm the link to this thread to ROCK so he's aware but don't dispare... just check those areas and have all the info ready for RRM if things don't get corrected. That way they can help you and figure out what's going on. Also some people have tried to run STAGE 2 setups with the 2nd cat in place and some even with the first... that's not good and the piggy isn't set up for that. You need a header/test pipe on there as well as an axle back or catback exhaust. The exhaust for that much boost/heat needs to be free flowing. Good luck guys and hang in there as it will get resolved.
OK..update... I am an Idiot and switched my vacuum line to the cruise control and to the stock fuel regulater thingy(?) I'm not exactly sure but anyway, switched the lines, car is running better now. I am still having some hestation at WOT..but maybe the ECU needs to relearn after running poorly for so long.... I might just unhook the battery and let it reset itself.
Dookie... My idle was stumbling horribly unitl I replaced my injector seals, got new plug wires, and pressure tested my system. Now it idles perfeclty.
Yeah my problem, as far as I know, is at idle only. I don't have a wideband installed, so I'm not for sure. I can smell the excess fuel coming from the exhaust when it is at idle though. Boe, I re-flashed the piggy back with the program you sent me, so everything is back to what it was originally. (10.4 at idle) Can too much fuel pressure cause this? As in the FMU allowing too much pressure? Can anything to do with fuel pressure cause an over-rich condition? I'm still in Texas, so I can't really do much with the car until I get home. I will start my trip back tomorrow. By the way, driveability is still great on the highway. Gas mileage is great and in the 1,100 mile trip I took, I had one stalling issue in Albuquerque, NM which I think was caused by the high elevation. (5,500 ft.) I never once had to shift out of 5th gear to go up any hill, as the boost gauge would creep up to 0 or 1 to 2 psi to go up the hill. I just need to get this light fixed and I am good.
Also Boe about smog inspections in Nevada, there is no visual inspection at all. As long as the light is out and the idle is good, the car will pass.
