My RRM Turbo
Originally posted by hardcoretuner
keeep up? god we are screwed i can't stand wrx's
my goal is what it always has been to beat wrx's and v6 mustangs and if at all possible mustang gt's so i can write 5.0 killer on my car
You may be able to take WRX's and most V6's in a straight line, but the WRX and most stangs will take you in any turns if their drivers know what they're doing. FWD is by far not the best high power platform.
EDIT: And I doubt you'll be taking anything but 4's running only 5-6psi.
So how was the install on an automatic??? Looks like the same thing as manual if you arent running a intercooler....is that correct rock?? Kit is the same for auto and manual unless you want an intercooler???
Originally posted by HobieKopek
Mustang GT's in their most recent incarnation are 4.7L
those cars are torque monsters 260hp but 302lb./ft.!!
Only limitation is the automatic. Nam can go more boost if he wants to risk transmission. We have not tried more on automatic cause we didn't have one for a long period. With big trans cooler and GOOD GAS he could probably go 7-8psi. But I would wait and see how trans handles 6 psi for a while!
ROAD/RACE
http://www.roadracemotorsports.com/
http://www.carbontrix.com/
ROAD/RACE
Uh...typo?
Rob do you guys have an official Road Race test car or are you still testing on customer installs? I know Mistubishi was jerking you guys around for a bit so I figured I'd ask.
are u plannin on gettin a BOV? also, i think u should get a turbo timer so ur turbo will be ok.
u wouldnt be able to take a wrx with a turbo lancer since the wrx is AWD and at 227hp runnin 14psi. the only way u would take it would be if you had a i/h/e plus fuel mods, a chip, runnin at higher boost, and other ish because the AWD makes a significant difference.
Actually I believe a turbo Lancer could take a WRX if you have a setup like Liquid's Lancer. If you are getting almost 200 hp to the wheels of a Lancer you got just as much hp as a WRX. That combined with a good LSD I'd say the Lancer could definetely take a WRX. I also believe a while back that Rock said a Turbo Lancer could take a WRX and since he works regularly with both, I'd take his word on it.
Originally posted by cleofis
from what i've heard..a turbo lancer did take a stock wrx. but mind you it was stock. the weight of the lancer is what did it. the hp + lightweight took the heavy wrx
Yep. Boni's car took at least one and Liquid's done a couple too, but Liquid is NOT running 5-6psi so you know. He's running 8-9 Psi and putting something in the vicinity of 200hp to the wheels. No LSD though. None of the turbocharged Lancers have LSDs at present unless they just haven't updated their registry entries or said so in threads.
