I Have The Intercooled Turbo With Safc2!! Help
Old Feb 19, 2005 | 03:41 PM
NITROHEAD's Avatar
Hi,
I have the SAFC 2 with the RRM intercooled kit. It all runs fine. The thing is i want to be able to use my SAFC2 It is hooked up and works fine. The reason i want to use it is because i paid for it to be installed and its fiberglassed it. So i want to find a way to use it. I heard that its no good. So what i wanted to do is get some RX8 injectors and install them. Will it work since i have bigger injectors. What should i do to get this thing functional? Let me know thanks. And will i see any Gain? Im also going to get RRM headers and boared intake mandifold and thorttle body. So now i just need to get it tunned. Please help Thanks
Nick
Old Feb 19, 2005 | 08:45 PM
Boeturbolancer's Avatar
For the boosted lancer the SAFC will only work to tune out bigger injectors. Don't go to big though or you won't be able to get your driveability right. I recommend no bigger than 440cc's which is about double the stock sizes. You should be able to tune that in with relative ease and get fuel trims where they need to be for daily driving.
Have a shop do it for you to be safe... also make sure the injectors you use are high impedance injectors. Low's won't work... you can put a resistor inline with them to get them to work but it's kindof a side fix rather than just getting the right impedance injectors. Good luck.
Old Feb 21, 2005 | 12:12 PM
NITROHEAD's Avatar
Hi, Thanks i was gonna have AMS tune it. For injectors i was looking at RX8 injectors. Have any other i ideas?
Thanks
Nick
Old Feb 21, 2005 | 04:46 PM
NITROHEAD's Avatar
Will these work?
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW
Old Feb 21, 2005 | 05:32 PM
Call RC with that part number and see if their high impedance... if they are they should work... you may have to modify the fuel rail a little for fitment.
Old Feb 22, 2005 | 02:34 PM
KillahB's Avatar
Those are saturated injectors; you should be good to go. Looks like they would fit perfectly, even though I dont know if the clips will be the right one.
dadsgts
Lancer Engine Management / Tuning Forums
Jul 7, 2013 09:54 PM
abuelo ralliart
13
Sep 25, 2009 01:42 PM
NITROHEAD
10
Jan 18, 2008 12:46 PM
NITROHEAD
Jul 12, 2004 02:32 PM
EvoHopeful
10
Sep 21, 2003 11:19 AM
