Stage 2 turbo Install!
Old Mar 1, 2005 | 09:06 AM
OZLancer1's Avatar
I recently purchased a used RRM stage 2 turbo kit and some friends and I are getting ready to install everything. I will be posting pics and all that good stuff as I go, but first I have a few questions. I've checked some piggyback ecu threads and most of them didn't say anything about turbo lancers. When installing the unit, do I have to do anything differently than NA lancers (Installation or learning period) since my car will be boosted? Also, will the kit bolt to any aftermarket header or just to the RRM header? The kit didn't come with a BOV, do I need to get a special flange or have anything welded? Or can I just get a universal and clamp it on the pipe? Also, I was wondering if anyone who has installed an RRM kit still has their instructions either in paper or in pdf or somthing that they could fax to me or email me. If not, I guess I can call RRM. Any help I can get would be greatly appreciated. I can't wait to get started and post some pics and info. Thanks everyone.
Old Mar 1, 2005 | 09:08 AM
travelsize420's Avatar
good luck man, take lots of pics
Old Mar 1, 2005 | 09:13 AM
Guru_Del's Avatar
well i can answer all your questions. here goes.
The piggy is installed the same way and has the same learning period.
This will only bolt to a RRM header as the up and downpipe are made specifically to fit either the stock header or the RRM one. If you do not have one you should get one as stage 2 will not work well with a factory header, infact i believe it is required to have a header.
As for the BOV, the pipe will have either a straight peice on it or a flange to bolt on to, if it is straight then a stock 1 or 2 g bov will go on with a clamp, if you have a flange then you can bolt on a Greddy type s bov,
Here is a link to my pics when i had stage 2 with a greddy bov
http://www.delperdang.com/photos/turbolancer
As for the install docs, check your pm's for more info.
Old Mar 1, 2005 | 09:32 AM
psionic98's Avatar
those pics are way better than the original pics posted guru!
Old Mar 1, 2005 | 09:42 AM
Guru_Del's Avatar
thanks, i have a ton of them but i keep forgetting which computer they are on hahaha.
Old Mar 1, 2005 | 11:24 AM
OZLancer1's Avatar
I just found out that my kit is missing a few items. I need the fan, a fuel pump, and I need to know what kind of spark plugs the RRM kit comes with. Also, are all fuel pumps universal? Or will only certain kinds fit in a lancer?
Old Mar 1, 2005 | 03:58 PM
Guru_Del's Avatar
check your pms
andymilonkis453
Apr 1, 2010 11:32 PM
NITROHEAD
10
Jan 18, 2008 12:46 PM
10thAnv
Apr 27, 2007 12:51 PM
livelyjay
11
May 19, 2005 03:01 PM
Lancerguy'03
Feb 2, 2005 10:57 PM
