turbo questions
Old Feb 11, 2003 | 10:05 PM
evo_dan's Avatar
Originally posted by 2wdSQL
That auction is for a complete Turbo. The auctioneer is telling you that the housing on the auctioned turbo is not polished Jesus what happened to reading skillz peoplez?
Look at the very last picture. Only the compressor side is shown and the exhaust side is missing. If it was there you would still see it behind the compressor side as it is larger. He also states you only get the compressor housing with the compressor and exhaust turbine. Reread it and I'm not talking about the single bold sentence at the bottom of the page.
Old Feb 11, 2003 | 10:12 PM
zlancer's Avatar
no its for a whole turbo. that last picture is just to show the compressor turbine as an example.
Old Feb 12, 2003 | 12:37 AM
2wdSQL's Avatar
Turbo has an exhaust turbine A/R of .48 and a compressor trim of 60
The CHRA is a reman peice that has been balanced on the New Autotrack 2000 Heins balancing machine
The Turbonetics Compressor housing has a very favorable, large 3" inlet for less restriction.
This turbo will support up to 300 HP on any 4 cyl engine from 1.6 to 3 liters, with boost up to 25psi.
Turbo can be used with internal or external wastegate.
You will not find a better turbo for the money, I gaurantee it!
Not to beat a dead horse or anything
Things that worry me in bold. Also EvoDan that compressor housing is polished as the seller states the turbo does not come with a polished compressor housing so that cannot be said turbo for said former auction Anyays the auctioneer here is a big moron; or just another one of those I don't know how to read or write in english sellers which I dislike o so much in any event. NMP.
Old Feb 12, 2003 | 12:40 AM
evo_dan's Avatar
But no exhaust housing.
This dead horse is now a beaten pulp.
Old Feb 12, 2003 | 12:46 AM
2wdSQL's Avatar
As we both know T3s usually come with internal wastegates on their (missing here) Turbine Housing.
Old Feb 14, 2003 | 02:33 PM
Obsoleteasian's Avatar
Originally posted by Joka
i was reading about someone making a custom turbo setup, he said it only cost him 2 grand. that i can probably afford. any ideas?
you get what you pay for... easy as that.
Old Feb 14, 2003 | 02:41 PM
HobieKopek's Avatar
If you mean motojoe, he knows turbo systems and did everything himself. If you have the tools, material, a second car and free time then a custom, homemade setup is a great way to go.
Old Feb 14, 2003 | 02:46 PM
reddog's Avatar
Let's sum this up, unless you plan on doing the labor yourself, and the custom fabbing (sp?), you're gonna spend the same if not more as the kit would cost. In other words, under these circumstances you're better off with the kit.
