Turbo kits through vision imports
Old Apr 10, 2002 | 03:51 AM
nezoid's Avatar
I've emailed Matt over at visionimports (they get there stuff from RPW) about there kits I’ve heard about.
This is what he replied:
Stage 1 turbos come with the following:
Garret T-25 Ball Bearing Turbo - rated to 300hp incl internal waste gate control set to 7 psi. RPW Custom Turbo manifold with External Waste gate option.
RPW Custom mandrel bent dump pipe incl flex pipe to catalytic converter.
Oil feed and return lines & fittings supplied.
Water feed fittings supplied on turbo. Four modified high flowed injectors Bosch plumb back blow off valve. Unichip computer controller (Piggy back to standard computer) - pre-programmed.
Slim line thermo fans for air conditioning and radiator.
Stage 2 comes with the following:
Upgrade of blow off valve to Turbo smart Type 2 plumb back design.
Upgrade of air filter to K&N Filter charger kit specific to Air Mass Sensor. with Cold Air Feed. Upgrade of throttle body to RPW 55mm Oversize unit and matching machined intake manifold. Fitment of level 1 decompression plate for boost levels over 7 psi.
Heat treatment of turbo manifold for reduced under bonnet temperatures Fitment of FSE Power boost rising fuel pressure regulator.
Piping can be supplied for cold air feed for air filter.
Stage 1 turbo grind camshaft available with valve springs.
Fitment of Vernier camshaft sprocket with either Camshaft or Decompression head gasket.
Stage 3 comes with the following:
Turbo upgraded to T-28 ball bearing turbo - 300 - 400hp rating.
Use of external waste gate control 45mm diameter. Fitment of Turbo Stage 1 or larger turbo camshaft and valve spring upgrade.
Fitment of level 2 decompression head gasket. Upgrade of Unichip controller to full Aftermarket computer - we recommend either Haltech or Motec systems. Motec may be available to fit inside original computer boxes for emission control purposes. Settings above 15 psi will definitely require internal modifications - conrods, pistons above 15psi. Probable fitting of extra 5th & 6th injector assemblies.
Upgrade of fuel pump assembly.
Pricing
Stage 1 $2,400
Stage 2 $2,878
Stage 3 $5,150 <-- ouch!!!
Sounds good… maybe. Should I through the work of doing it this way or just go with RRM?
Old Apr 10, 2002 | 04:53 AM
2wdSQL's Avatar
Well isn't the problem for you that you're in CA and they're in Florida. Why not stick with Road Race since your soo conveniently close to you. FL is even a stretch for me and I live in Virginia. Unless you were planning on purchasing a Turbo kit and installing it yourself.
Old Apr 10, 2002 | 05:05 AM
EVO7's Avatar
I would stick with RRM unless you have any Knowledge on how to install a Turbo kit or have someone to do it for you. or have some extra money to pay for it to be installed..
Old Apr 10, 2002 | 06:06 AM
ryland's Avatar
Turbos are new to me
Turbos are new to me. Whats the deal with the stages? Is it the higher the stage the bigger the turbo? which equals more hp?
Old Apr 10, 2002 | 06:43 AM
2wdSQL's Avatar
The stages are just what they call their different steps for a Turbo Build up on a Lancer.
Old Apr 10, 2002 | 06:44 AM
yellow_lancer's Avatar
does anyone know how much hp and torque each stage will produce at the wheels?... thats what i want to know... thanx
Old Apr 10, 2002 | 06:46 AM
.....also...
are those turbos stable? i heard t-25 and t-28 blow easily....maybe i heard it doesnt blow easily...hmm im confused now... some info would be great.....
Old Apr 10, 2002 | 07:12 AM
2wdSQL's Avatar
170 to the wheels running 7PSI with intercooler I believe on the T-28 Spool is at 2000RPMs I think so there's no lag either. Whether the explode I have no idea, but I highly doubt they'd be using them for performance applications if it was prone to serious or early failure.
Old Apr 10, 2002 | 07:47 AM
170 to the wheels at only 7psi? are you sure?? wow...thats pretty impressive.... isnt the evo 7 like 190 to the wheels at like 13psi?? so almost double the boost and only 20 more hp then the sohc 4g94 engine? hmmm something isnt right here .....but if its true..... wow.....dats all i can say
Old Apr 10, 2002 | 07:58 AM
2wdSQL's Avatar
LMAO AWD has more powertrain HP loss. The WRX dynos in at 150HP.
Old Apr 10, 2002 | 08:04 AM
oh yeah.... thanks...you cleared up a lot for me... i forgot how much awd takes away... well im going to start saving for the stage 3.......:headbng2:
Old Apr 10, 2002 | 08:13 AM
2wdSQL's Avatar
I wouldn't do that if I were you. That requres an engine reuild which currently can't be done on a Lancer by simple part swapping. They would need to machine you pistons, rods and change your cam profile or replacement of it totally; new valve springs.
Old Apr 10, 2002 | 08:36 AM
uhhh...lancer is going to be my show car... i have another car by the way....... i only bought it to one day make it a 11 second car... my everyday car is an SUV...isuzu trooper... its okay... real comfortable to drive....
Old Apr 10, 2002 | 08:41 AM
2wdSQL's Avatar
I see. I'd say for a stage 3 you'll be looking at more like 7Gs of work and parts. Don't forget the computers BTW you'll need those.
Old Apr 10, 2002 | 08:47 AM
yeah... i know what your talking about... but if you want speed... you need the money.. and im thinking about putting in like 15-20 grand into the lancer before im done with it....
