Oil return...can it be done through drain hole?
Old May 15, 2005 | 04:03 PM
Kelspar's Avatar
I was just curious if you could thread an adapter (not sure if thats what you would need) to screw into the oil drain hole. Would there be a problem returning through that? Just curious......
Old May 15, 2005 | 04:09 PM
Archangelite's Avatar
no problem, but what will you do when you need to change your oil? maybe a 'T' fitting will work?
Old May 15, 2005 | 04:10 PM
Az3ar's Avatar
Yes there would be a problem. See the oil return line must be above or at the same level of the oil level in the oil pan... being under the oil level will cause oil pressure and you don’t want that for the oil return line. Pick the highest spot in the oil pan and drill it.
Az3ar's Avatar
not a good idea, I speak from experience.
Old May 15, 2005 | 04:13 PM
Kelspar's Avatar
Cool thanks for reply; i was just wondering, figured it may have come up but couldnt find it.
Old May 15, 2005 | 06:28 PM
HobieKopek's Avatar
Az3ar is correct. Oil returns are SOLELY gravity fed, and you do NOT want to swamp your turbo. Tap the pan. It's not exactly the most difficult thing in the world. And yes, it's been asked and answered at least a few times that I know of.
Old May 15, 2005 | 06:36 PM
Az3ar's Avatar
dam you have 10K post lol
Old May 15, 2005 | 06:38 PM
AznFlip's Avatar
sorry off topic... where do you ctap the oil feed/return line anyways?
Old May 15, 2005 | 11:08 PM
KillahB's Avatar
Any competent shop should be able to tap your oil pan... all you have to do is show them where. I took my pan to a driveshaft shop and showed the guy where I wanted it tapped. 20 bucks and 1/2 hour later, voila.
I have my oil feed T'ed off the oil pressure sending unit at the back of the block.
Old May 16, 2005 | 07:17 AM
HobieKopek's Avatar
Same. They make fittings where you just drop the pan, clean it, drill it, and bolt it on w/ some sealant to keep it from leaking. That's what I'm using now. It can be threaded (the pan itsef) or it can be left unthreaded, but the threading should help prevent turning, loosening or leaking. There are also punch style drains that I know of, and probably a couple other kinds as well, but if you look you'll find something that suits your needs. If not, a shop will do it for you like Airquez said. But remember that turbo oil returns are GRAVITY fed, and that swamping your bearings means the DEATH of a turbo.
Old May 17, 2005 | 07:41 PM
smokin_oz03's Avatar
how about where the oil filter is? and does anyone maybe have pics of the tapped pan, so as i can get an idea where?
Old May 17, 2005 | 07:46 PM
Az3ar's Avatar
did you read what he said above???
"remember that turbo oil returns are GRAVITY fed, and that swamping your bearings means the DEATH of a turbo"
Old May 17, 2005 | 07:50 PM
Hotshot940's Avatar
yeah you have to have a gravity feed for the return, if you plumb it into the drain your actually trying to push oil back up and through, just get it tapped the right way and have no worries, there is no way using the drain will work.
Old May 17, 2005 | 09:03 PM
any pics of where on the drain pan?
Old May 17, 2005 | 09:05 PM
AznFlip's Avatar
^ Bump
