Oil return...can it be done through drain hole?
That tap is into the block no? Well i have a question; i went to a local shop and when i tried to explain the procedure to the guy he was all confused and stuff. I dunno if he understands what im talking about. He told me i had to have a nut welded on the inside so it would have something to hold on to. Now from reading the posts around here i havent seen a person say that; i just thought you tap and thread the oil pan, is it thick enough? Plus he wants 50$ too expensive?
It's not necessarily the BEST way, but it's one way. Yes.
EDIT: That's how mine is done (mine is threaded too though), and though I do get a drop of oil coming out every now and then it's minimal and seems to be coming from the drain hose, not the oil pan.
I think i will do that; just drill with 5/8 bit and bolt it with sealant? sorry i know im saying the same thing over and over but i want to be 1000% clear; doing install this sunday; new oil pan comes in tomorrow.
I apologize; i should have done more research. After carefully researching it i now know that you tap the UPPER oil pan. I am having it done tomorrow by my uncle. Only other thing we were unsure about is that it is a 5/8" tap you use.....Once again; sorry for the ignorance.......but i learned alot!! Install still coming sunday, stay tuned!
-Heath
-Heath
trinibt65
Aug 22, 2015 01:42 PM
