Somewhat disappointing dyno
Old Aug 31, 2005 | 05:37 PM
imapunkclaimer's Avatar
nevermind im stupid
it was actually doing like 8 psi cause of a boost leak i just found. i probably should checked the boost gauge, but whatever. 200whp@8 psi it what it really boils down to.
Old Aug 31, 2005 | 06:02 PM
Boeturbolancer's Avatar
that doesn't sound right... but of course it is like 100 degrees out today.
Also your running the high flow cat... guess that could be costing you a couple ponies.
I'm interested in seeing the torque numbers as well.
Old Aug 31, 2005 | 06:24 PM
fix it for me and ill redyno it later!
Old Sep 1, 2005 | 07:13 AM
Will do...
Old Sep 1, 2005 | 09:43 AM
Go_Lancer_Go's Avatar
can u post ur dyno sheet??
Old Sep 1, 2005 | 12:11 PM
yeah post what 8psi did... it'll be good to see. Also can see the leak since your power doesn't spike up till way late. The dyno shows a lot. Just need to know what your looking at.
Wish they had the torque curve... call them guys up and get it.
Old Sep 1, 2005 | 03:51 PM
KillahB's Avatar
Sounds awfully efficient (and suspicious) to be getting 200 whp at 8 psi with a boost leak. Post up the dyno sheet.
Old Sep 1, 2005 | 04:08 PM
he's supposed to be at 230+whp at 9psi so i think 200 at 8 with a leak isn't suspicious it actually explains things a little. He's overly rich due to the leak and boosting less. That could easily drop you 30whp.
From what i saw on the dyno sheet it stayed around 185-190 until the tail end where it jumped up to 200 range... this would show that the turbo under the higher rpms was making up for some of the loss but not all.
Old Sep 1, 2005 | 04:12 PM
why was he only running 8psi though?
Old Sep 1, 2005 | 07:49 PM
OZLancer1's Avatar
When you have a boost leak, it prevents the turbo from hitting peak boost levels because you're losing boost pressure somewhere.
Old Sep 2, 2005 | 10:56 AM
^^ exactly...
Darknightevo
Dec 16, 2010 07:11 AM
griffeyr
36
Dec 22, 2008 02:21 PM
Yaroslav
42
Nov 21, 2005 05:13 AM
J8dailo
12
Oct 27, 2005 09:01 PM
Blue Evo 8
11
May 26, 2003 04:29 AM
