manual boost controllers...
Old Sep 12, 2005 | 09:17 PM
Go_Lancer_Go's Avatar
so w/ my rrm stage 2 kit i dont think im hitting 9psi...
so i was gonna get a boost controller but the electronic ones are expensive!
i was thinking of getting a manual one for cheap like $50.00
question is...are they worth it, will i be hitting 9psi w/ it
i heard they suck cause they have this dial and u dont actually know how much boost ur hitting unless u have a boost gauge (which i have)
i jus want ur guys view on it
mostly im asking, am i wasting money if i get this! i wanted to run it by u guys b4 i bought it.
Old Sep 13, 2005 | 05:01 AM
OZLancer1's Avatar
I don't think a boost controller will really help you if you're already having problems reaching 9lbs. It probably means you have a leak somewhere, which means even with a boost controller, you'll still have the problem. You may have the ability to hit 9lbs with a controller, but you will still have a leak/problem somewhere which could cause more problems down the road. I'd check everything out before you get a controller.
Old Sep 13, 2005 | 05:05 AM
liquidlancer's Avatar
what kind of boost numbers are you seeing?
you can use starter fluid to find your boost leak if your having one just hose down the couplers and stuff with it the idle will raise once youve found it
Old Sep 13, 2005 | 06:47 AM
ya ill try that but RRM thinks i might have not gotten the right wastgate spring
Old Sep 13, 2005 | 06:52 AM
Silver05Bullet's Avatar
I can sell you a turbo xs boost controller for 50$ + shipping but your problem is probably not related to the boost controller as someone said earlier.
Old Oct 16, 2005 | 01:24 AM
grubiaco's Avatar
Did you end up buying a boost controller? Or was it the wrong spring?
Old Oct 16, 2005 | 01:43 AM
i bought a boost controller jus havent installed it yet
Old Oct 16, 2005 | 02:02 AM
imapunkclaimer's Avatar
i dont think the spring is exactly for 9 pounds. it might be more like 8ish. call em up and ask them before you drop unnecessary cash
Old Oct 16, 2005 | 12:01 PM
grubiaco's Avatar
Are you going to tap into the BOV line? Also, once you install you can change boost (higher and lower) despite the spring you have in the wastgate?
Old Oct 16, 2005 | 12:08 PM
ya the sh|tty part bout a manual boost controller is that once u adjust it u have to like sit there and take it for a spin to see what its sitting at...
Old Oct 16, 2005 | 12:19 PM
SuckaFree's Avatar
does every turbo kit need a boos controller and why or why not? sounds like a school question?
Old Oct 16, 2005 | 12:31 PM
grubiaco's Avatar
So my statement was correct, right? Despite the spring in the external wastegate you can change the boost if you tap your manual boost controller inline with your BOV line.
Old Oct 16, 2005 | 01:27 PM
grubiaco's Avatar
Disregard the previous post...Go which boost controller did you buy. Also, if you go to the hallman website there is a nice install posted.
Old Oct 16, 2005 | 10:14 PM
Sonantoni's Avatar
You tap the turbo------>wastegate line, so it becomes
turbo------>bc-------->wastegate
evodrivesme
13
Jul 13, 2023 07:18 PM
khaled_hourani
15
Apr 24, 2017 04:10 AM
Go_Lancer_Go
For Sale - Part Outs
23
Aug 12, 2006 02:46 PM
Joeballz
34
Jul 31, 2006 10:24 AM
David Buschur
AEM EMS
27
Oct 27, 2005 06:34 PM
