Rob P's Custom Turbo Questions
Old Sep 28, 2005 | 09:24 PM
  #31
schepis's Avatar
Originally Posted by AznFlip
What's RFL?
Probably the TurboXS RFLs....Really ****ING Loud
Old Sep 29, 2005 | 06:33 AM
  #32
silkymp's Avatar
Originally Posted by rhyzin
okay, i read that. if i read it correctly, the wastegate doesn't rely on manifold pressure anymore and relies on the tension of the spring in the wastegate to open at certain boost pressures? that's kinda iffy with me unless someone has tried this on the t25. its has grounds for working and stopping boost at a certain psi, but you may also leak boost down low. a proper wastegate should prevent leaks during spool up. i personally have not really seen this method before. are there a lot of instances where people do this?
I was running searches and found one guy that was doing this with his honda i believe, and he said it worked fine. But that was the only person i've heard of that has actually done this.
Old Oct 2, 2005 | 04:59 AM
  #33
datdjrobp's Avatar
Old Oct 3, 2005 | 11:47 AM
  #34
datdjrobp's Avatar
apparently it doesn't update if i edit the last post....
okay, here's a semi decent question to ask. how does a mechanical oil pressure gauge work? keep in mind i said mechanical, not electrical. oh, and on that same subject, if you can give me an argument for using either, i'm all ears.
Old Oct 3, 2005 | 02:48 PM
  #35
HobieKopek's Avatar
Probably the same as electrical, only there's not an external electrical sender.
(Meaning the pressure sensor is probably part of the gauge.)
Old Oct 3, 2005 | 03:07 PM
  #36
datdjrobp's Avatar
okay, so with a mechanical one i'd actually have oil running into the cabin? that sounds like a mess.....
Old Oct 3, 2005 | 11:22 PM
  #37
HobieKopek's Avatar
I'd imagine. I've never seen a mechanical oil pressure gauge though. I have seen PLENTY of mechanical fuel pressure gauges, but most of them are underhood since it's illegal (not to mention ****ing stupid) to run fuel through the firewall on a street car.
Old Oct 10, 2005 | 06:59 AM
  #38
datdjrobp's Avatar
HK, pics of the turbo will be available shortly. UPS has it "out for delivery".
Old Oct 10, 2005 | 10:02 AM
  #39
datdjrobp's Avatar
I heart the mailman.
Attached Thumbnails Rob P's Custom Turbo Questions-p1010001.jpg   Rob P's Custom Turbo Questions-p1010002.jpg   Rob P's Custom Turbo Questions-p1010003.jpg   Rob P's Custom Turbo Questions-p1010004.jpg
Old Oct 10, 2005 | 12:39 PM
  #40
AznFlip's Avatar
Nice. So you're going to run 9psi with that?
Old Oct 10, 2005 | 12:42 PM
  #41
datdjrobp's Avatar
i still think i'm going to get an external wastegate and set it lower for now. i know 9 is the absolute upper limit of what stock internals can handle but i don't want to push my luck.
EDIT: i also still haven't confirmed this wastegate is set at 9psi.
Old Oct 10, 2005 | 01:00 PM
  #42
rhyzin's Avatar
yowza. looks like any hopes of an external wastegate is going to have to be pre-turbo. that turbine outlet flange must be a euro thing. i don't think i've ever seen that style on an import for a t-25.
Old Oct 10, 2005 | 02:04 PM
  #43
datdjrobp's Avatar
hey rhyzin, are there normally threads on this thing?
Attached Thumbnails Rob P's Custom Turbo Questions-p1010005.jpg   Rob P's Custom Turbo Questions-p1010006.jpg
Old Oct 10, 2005 | 02:28 PM
  #44
rhyzin's Avatar
threads on the wastegate? not that i've ever seen. it even has a flange for the wastegate to mount on. i haven't seen one of those either. it seems like a t25, but it's really weird. i'm sure it's just a euro thing.
i guess the threads are just to make it adjustable. it can adjust the tension of the wastegate onto the wastegate flapper. kinda like from the link silkymp posted, but not quite the same purpose. anybody else seen this version of the t25?
Old Oct 10, 2005 | 02:35 PM
  #45
datdjrobp's Avatar
that's kinda what i was wondering. so i could basically, in theory, apply my own boost leak in order to keep it under 9psi?
well, as is normal with most things i do, i run into the oddball situation. Yoo Neek!
