Intercooler Question
Old Oct 15, 2005 | 10:39 PM
jchangsta2six's Avatar
so in other words .. its bad to just run a i/c without turbo ...
and ozrally where did you get that kinda deal?
Old Oct 15, 2005 | 10:45 PM
drucea's Avatar
i dont think it dont know what it would do without a turbo or SC. just get an intake.
Old Oct 15, 2005 | 10:48 PM
ozrally0303's Avatar
some evo owners
Old Oct 15, 2005 | 11:41 PM
wow you got the hook up ozrally ...
Old Oct 16, 2005 | 12:09 PM
SuckaFree's Avatar
qustion for you guru's i want to get a basic turbo setup. Nothing big now just run 5-7 boost. I will upgrade later but for now thats it. I weant to build a good kit that will last a long time and many many miles i do travel. What intercooler should i look at getting and do the evo intercooler pipes work for our cars. And will having an evo ic hurt my performance and or cause damage to the kit?
Old Oct 16, 2005 | 12:37 PM
grubiaco's Avatar
The evo intercooler pipes will work to a certain extent. YOu will have to do some custom fabrication, though. I personally want to know what size will give you negative results. The reason why I am asking is because I think, if someone uses piping (2.5" like aftermarket evo piping) we will get some static pressure drops and instead of running your desired lbs it will go down. Also, if this is confirmed that it will happen, can this be remedied through a boost controller and upping your boost levels do where it was originally at?
Old Oct 16, 2005 | 12:42 PM
bahamut's Avatar
Originally Posted by datdjrobp
is there such thing as overkill on an intercooler?
yes.
You have to find each IC flowrate.
If you making around 200 HP at wheel and using a IC that is capable of +400 at wheel HP, the IC is too big.
Old Oct 16, 2005 | 04:28 PM
what is a good size intercooler to go if i just wanna say N/A ...
Old Oct 16, 2005 | 05:28 PM
rhyzin's Avatar
none.
Old Oct 16, 2005 | 05:35 PM
EVILutionVIII's Avatar
Veteran: Air Force
I hope this is a joke. If you're n/a, there is absolutely no reason and no benefit from running an intercooler. It will hurt your performance.
Old Oct 16, 2005 | 06:09 PM
drucea's Avatar
well...you could put an intercooler on and put a filter on one end then run the other end up to your throttle body...but it will still hurt your performance.
Old Oct 16, 2005 | 06:12 PM
Veteran: Air Force
I'm lost.....what was the point of this again?!? Obviously not performance. For the price of an intercooler, your money could be spent on something that your car could actually benefit from......
Old Oct 16, 2005 | 06:15 PM
drucea's Avatar
i guess he was planning to go turbo and wanted to know which intercooler he could get that would fit, or if he could just get any intercooler... and my previous comment was sarcastic, just to point that out.
Old Oct 16, 2005 | 06:25 PM
Veteran: Air Force
I see
Old Oct 16, 2005 | 07:00 PM
maybe if he gets an intercooler it will be enough motivation to keep building his custom turbo kit just an idea thats wat i did with buyin a turbo
