Intercooler Question
Old Oct 8, 2005 | 04:35 PM
jchangsta2six's Avatar
will any intercooler fit any car?
Old Oct 8, 2005 | 04:37 PM
RobertK's Avatar
yes.
with work.
Old Oct 8, 2005 | 04:39 PM
define with work? like new pipes? thanking for asking this question .. you make my life alot easier
**As my buddy told me .. by adding just a intercooler u can rise ur hp like by 20 .. true? or is he a BSer
Old Oct 9, 2005 | 02:09 AM
Drive02Lancer's Avatar
well with an intercooler u can raise ur boost levels. thats how u gain the HP.
and yes, any intercooler can fit any car.
you will need new piping to run to and from the intercooler.
you can have a sidemount IC like DSM's and 3kgt's....or u can run it in the front like most people do.
Old Oct 14, 2005 | 01:29 PM
SuckaFree's Avatar
Would the EVO III intercooler be over kill or would it work
Old Oct 14, 2005 | 01:49 PM
datdjrobp's Avatar
evo8 should work just fine. that's what i bought. is there such thing as overkill on an intercooler?
Old Oct 14, 2005 | 02:13 PM
ozrally0303's Avatar
ya there is
Old Oct 15, 2005 | 08:14 AM
KillahB's Avatar
Too large of an intercooler would actually create too much ofa pressure differential and actually hurt performance.
Old Oct 15, 2005 | 03:41 PM
the only intercooler kit i found with piping that will fit was on rrm. so i was wondering does anyone know where you can find a nice intercooler (just the intercooler, cause ill just have the pipes custom made) for close to 200 bucks ... if i need to spend more .. i think im am just going to go with the one from rrm ...
Old Oct 15, 2005 | 03:47 PM
its alot cheaper to just buy the evo setup i got the pipes for 20 bucs and the intercooler for 92 and it fits preety good
Old Oct 15, 2005 | 04:05 PM
drucea's Avatar
and if its too big you might have to do some body modification.
Old Oct 15, 2005 | 04:44 PM
grubiaco's Avatar
air would you say the evoVIII intercooler is overkill?
Old Oct 15, 2005 | 05:16 PM
rhyzin's Avatar
11.4"x19.3"x2.5" core is pretty damn big for only 5-7psi of boost. evos use this intercooler for 16-20psi stock. overkill for a simple turbo kit.
Old Oct 15, 2005 | 08:41 PM
KillahB's Avatar
If you are running this IC, with proper tuning, I would say bump it up to 10 - 12 psi.... I dont think it would be overkill in a situation like that. If you want low boost (which to me, having a turbo kit and running 5 psi, roughly 50 - 60 hp is pointless, just stay NA), then it might be too big, and you might want to consider something smaller.
Just go based on your estimated whp. If you are looking for 225 - 275 whp, I think that IC would be perfect.
Old Oct 15, 2005 | 09:24 PM
grubiaco's Avatar
What about piping? What size piping would you recommend if you were going to run 10-12 psi (as a daily driver)?
