First Dyno Run....*help*
Originally Posted by Lancerguy'03
Walbro....that is supposed to be the best brand....i think Denso makes one....i know they make like a 310 or 320....
wonder if that brand is quieter lol...the walbro's are quite loud, everyone is like "what the hell is that sound"
I can't believe they did the full pull with you running that lean... you're lucky your motor didn't pop.
You should NEVER go back to that dyno place!! Anyone willing to run you that lean under boost has no idea what they are doing!!
Fuel pump or FMU is what i'd say as well. Get cheap gauge from auto store and check the pressure or try replacing the pump.
. So yeah, I'll go to a different shop next time.Well I just ordered Walbro 255 this morning and it should be here by Friday.
man you are totally inspiring me to build my own....im really eager to see what kinda numbers you put down when everything is running as it should be. I know that this question is probably jumping ahead too far but any future plans to put together a "2nd stage" for your kit?
BUY MY OIL PAN )I'll find out my AFR this weekend once I get my fuel pump (wish me luck
Originally Posted by spydervenm
so did you get your new fuel pump? did it fix your problem?
I've seen alot of FMU's not work properly. I've only seen one bad walbro fuel pump and it just didnt work at all. The Begi regulators work well.
----> http://www.cnfxperformance.com/index...22_70_82_88_95
