Which size injectors should I get? If any??
Old Dec 27, 2005 | 10:20 AM
  #46
Lancerguy'03's Avatar
bump
Old Dec 27, 2005 | 03:41 PM
  #47
Ozturbo's Avatar
I have the RX-7 injectors in my car right now. I actually just reinstalled them last week since i have my wideband to tune them now. All that is need to install them are long fuel rail bolts ( about an inch longer, you can get them from Home Depot and a 1/4" spacer of some kind because the tip of the injector is longer than stock ( I used 1/2" copper tube and cut 4 1/4" rings for the spacers, pretty simple but there may be something easier). Also i had to remove the brace that connects from the throttle body to the head so the fuel return line could bolt back up since the injectors sit higher, this is just temporary i would suggest ussing a cut off wheel and removing some of the brace where the return line will be sitting. I can take pictures anyone would like.
Old Dec 27, 2005 | 11:58 PM
  #48
i was just want an "for sure" on the 2003 WRX injectors.....but thx for the info
Old Dec 29, 2005 | 01:06 PM
  #49
Bump!!!
Old Dec 30, 2005 | 10:18 AM
  #50
bump
Old Dec 30, 2005 | 01:07 PM
  #51
grubiaco's Avatar
Hobie how much did you spend on your injectors? I'm looking to get bigger injectors so if you guys wanna put up price ranges that would be nice. Thanks.
Old Jan 9, 2006 | 07:56 PM
  #52
rcefstsfecr's Avatar
I'll be getting a set (4) of 550cc used HIGH imp. injectors from a t2 rx7 for $65 as soon as the guy I know tells me he's ready to sell them to me.
Old Jan 10, 2006 | 12:29 AM
  #53
t2 Rx7??? what year is that?? does T2 mean twin turbo?
Old Jan 10, 2006 | 03:11 AM
  #54
grubiaco's Avatar
I would like injects for that cost
Old Jan 10, 2006 | 12:44 PM
  #55
Ozturbo's Avatar
I paid $80.00 shipped for the 460's
Old Jan 10, 2006 | 02:53 PM
  #56
ozrally0303's Avatar
no one answered the wrx question, what year will fit and will the stis?
Old Jan 10, 2006 | 03:09 PM
  #57
Ozturbo's Avatar
I believe when i was looking for new injectors any year of the WRX injector would fit in terms of size and impedance but i believe they use the standard bosch type connector so you will need to splie in connectors. Also i couldn't find a pair for under $200.
Old Jan 10, 2006 | 09:59 PM
  #58
http://forums.nasioc.com/forums/showthread.php?t=917069
and Hobie PMed me back saying the WRX injectors will work 2002-2003...im am asumming the 04-05 are the same injectors aswell.
Old Jan 10, 2006 | 10:59 PM
  #59
grubiaco's Avatar
I really don't want to splice...I would rather get direct plug n play.
Old Jan 11, 2006 | 02:14 PM
  #60
Go2fast's Avatar
Which one will just plug in ????
