well i did a compression check.....
Old Dec 16, 2005 | 01:08 AM
Lancerguy'03's Avatar
and the
1st CLY was
1st 149psi
2nd 153
3rd 154
4th 153
im guessing that is good??? stock internals and been boosting for about 27000miles! so i guess the turbo ist that bad for our cars after all.
what do yall think of the numbers??
Old Dec 16, 2005 | 01:44 AM
Hotshot940's Avatar
Those are lookin real good.
Old Dec 16, 2005 | 01:45 AM
Hotshot940's Avatar
when are you gonna step up to stage 2?
Old Dec 16, 2005 | 05:51 AM
Danno's Avatar
Not bad, you also have to look at how it got to those numbers too. (how the needle moved up)
Old Dec 16, 2005 | 06:03 AM
gregivq's Avatar
Looking good.
Old Dec 16, 2005 | 09:08 AM
it took the needle about 3-4 jumps before it stoped moving. im goin stage 2 when i buy the Split Second piggy and get bigger injectors. but i need suspention too.
Old Dec 16, 2005 | 09:19 AM
HobieKopek's Avatar
I thought standard compression was higher for our cars. Like around the 175-200psi range.
Old Dec 16, 2005 | 09:20 AM
Hotshot940's Avatar
i think my compresseion is around 151 in all cylinders. as far as how the needle got there, you should let the car crank for about a 5 count, any more and your risking burning up the starter, any less and you may not get a very accurate reading.
Old Dec 16, 2005 | 09:46 AM
no we did a 5sec crank.....175-200 is too high..our compression ratio is 9.5-1? correct?
Old Dec 16, 2005 | 09:52 AM
Danno's Avatar
Ya looking back on my old thread I was 180 on all 4. That is low.
https://www.evolutionm.net/forums/sh...d.php?t=162373
Old Jan 20, 2006 | 02:40 PM
-=triggrhppy=-'s Avatar
what is your oil consumption like?
Old Jan 20, 2006 | 02:41 PM
HPF Tom's Avatar
Within five across the board, good stuff!
Tom
Old Jan 20, 2006 | 02:45 PM
ROCK's Avatar
They are mostly the same. You are fine! If car was heated up more you would have higher numbers. Point is, it is all GOOD!
ROAD/RACE
Old Jan 21, 2006 | 09:30 PM
seems like the turbo is doing no damage to the motor! that is nice!!
Old Jan 21, 2006 | 09:41 PM
HobieKopek's Avatar
Yes, our CR is 9.5:1.
Service manual says Min 170psi, standard value 234psi. Mine were between 220 and 225 with brand new pistons and rings way back in the day.
