IM+TB+Turbo
IM+TB+Turbo
My question is... The horsepower i might make from the IM and TB with the turbo, is it worth the price? I already have the turbo, but before i spend another $800 on the two, i wanted to know if anyone else had done this and seen any good gains. I would search, but the computers here in iraq are reeeeeaaaaalllll sloooooooowwwww. Thanks for your help!
Our t.b. an ported manifold yielded about 10% increase in power. If you are tubo then figure on 10% of a bigger number. But what people have trouble getting their arms around is that the real benefit of such items is the quicker response and better power band! DO IT.
ROAD/RACE
ROAD/RACE
the throttle body is off a 1g eclipse that i sent to rpw and they bored it out to 63mm and adapted the tps and isc sensors for the 4g94..
I bought the intake manifold from a junkyard and ported it myself.
Why not take the initiave and make your own IM. I would say do your TB yourself but not many people are as lucky as me to have full acess to a full machine shop whenever I want and it takes a little more then a die grinder and patience for that.
Here is my take on all this....
For me, I have a 4G93so I already have the manifold. I ported it out to 60mm and was running an Eclipse 60mm TB. With this and the 2G Eclipse turbo MAS, when I was aspirated, I was running so lean that tthe car would throw a CEL if I didnt adjust the air / fuel ratios. Much more air. Turbocharged, that is all I knew, but I can tell you, the car hauled *****.
Wow. There is such a thing as too big a T.b. That is a perfect example. Going so big will require you to do a bunch of other stuff as well to compensate for the extra air.
ROAD/RACE
ROAD/RACE
That was when I was aspirated. Turbocharged wasnt a problem at all. I think 60 mm for most of our cars, fully streetable, is about the limit I would go.
Even though I have a friend in Trinidad, running a 4G92 SOHC, and he has a 67 mm TB and IM and was running mid to low 13s on stock internals.
I have an upgraded fuel pump, fpr and emanage to support the air flow, and I already had the 1g tb laying around so I just decided to go with it.
Cams would be nice but I havent gotten there yet.
maybe there is a way to lean out the lancer
