Raising PSI
Old Jan 23, 2006 | 01:38 PM
mitch44759's Avatar
Question Raising PSI
Hey Guys
I am Planning on putting in new piston heads and rods, my question is when i have this done how high can I raise the PSI with my current MOD's?
Thanks
Old Jan 23, 2006 | 01:41 PM
Lancerguy'03's Avatar
would not recommend it for the fact that u dont have an intercooler. and from what i gather anything over 7psi ur maxing out the injectors...so bigger injectors and some form of fuel control will be needed...
so to answer ur qestion...DO NOT RASIE THE BOOST.
Old Jan 23, 2006 | 01:42 PM
mitch44759's Avatar
I have the FMU that came with the kit that will not surfice
Hotshot940's Avatar
get an intercooler, then we'll tell you. Or you could do a search. Or you could go into the forced induction forum and look around for 5 minutes and find it.
Old Jan 23, 2006 | 01:43 PM
Hotshot940's Avatar
If your going to do full internals, you might as well spend the money and get a standalone. I consider the fmu a liability when planning on spending that much money and raising the boost any higher than 9 psi.
Old Jan 23, 2006 | 01:49 PM
gregivq's Avatar
Without an intercooler 7psi is your max, and not all the time. After getting the intercooler you can go up to 13psi on stock engine with decompression gasket + fuel managment.
So how about instead of spending all the money on the engine work, get some serious fuel managment unit + intercooler and then injectors and try maxing out whatever you have. If you will make a mistake then you can play with the engine.
Old Jan 23, 2006 | 01:55 PM
mitch44759's Avatar
thanks now that i have the turbo i want more speed, i just thought new internals were need to go any higher.
Thank You
Old Jan 23, 2006 | 02:02 PM
mitch44759's Avatar
does roadrace's intercooler mount up with there non intercooler setup
Old Jan 23, 2006 | 02:36 PM
Johns Slow ES's Avatar
i think it does but u have to tell them that ur "upgrading" or something like that cause ul need different charge piping
Old Jan 23, 2006 | 03:02 PM
sweet_bucket22's Avatar
stock internals on Lancer 2.0L have been pushed to about 12-13psi with no issues... at 14+ things break.
Thus you should just hold off on the internal mods and get an intercooler. More power... then stage 2... more power... then upgrade the motor and get standalone if your gonna go further.
Or some have upgraded the motor and switched to emanage with bigger injectors and pulling timing.
Old Jan 23, 2006 | 03:04 PM
ROCK's Avatar
We have the IC upgrade kit for the Non IC guys. Go ahead and give a call. Lot cheaper and alot easier than changing internals.
ROAD/RACE
Old Jan 27, 2006 | 11:05 AM
mitch44759's Avatar
where can i purchase a decompression gasket?
Old Jan 27, 2006 | 11:20 AM
blaze_125's Avatar
Accolade is now a reseller of RPW. Contact dave@accolade
Old Jan 27, 2006 | 08:19 PM
ROCK's Avatar
We boosted 13 psi with FMU and Stage2 (basically) stuff on our drag car. FMU still serves a purpose. Decompression gasket works for certain applications. Like we will try one on our drag car but only because it is a drag car and we went for bigger turbo. For drivability, like WRC cars, they run small turbo and high compression pistons. That is what gives them responsiveness and ability to steer with their throttle more. My GSX Rally Car has 9:0 to 1 compression pistons. That is more than stock along with BIG 16G turbo! Sweet!
ROAD/RACE
Old Jan 28, 2006 | 02:40 AM
omarboy25's Avatar
good luck on raising your boost you must be hungry for power
im pushing 19 psi on FMIC, RPW head, rods pistons, decompression
head gasket...RRM parts and other goodies you can do it
upgrade to that RRM IC kit and you will be at another level
