stock srt-4 vrs stage 2 turbo
an VIII will beat a mildly modded srt from a dig, however, even a stock srt will walk a stock evo from a roll, no question asked (though the 05' are darn close). the IX's are differnt. those puppies are quick, the mivec allows for a broader powerband. any srt owner who says otherwise is a weiner.
this thread was started to compare a turbod lancer vs srt4's. all the problems that make the srt suck butt, will also afflict the lancers, so it comes down to power:weight.
Lancerguy looking at your dyno I see your car running very lean..I sugest you not to put more boost than what was posted in that dyno BC's you are not going to make much power and will risk your engine. You should try to get your AF under 11.5 to be on the safe side and maybe will make even more power than what you have right now. Do you see how the curve ends up looking like a ruffle chip after 3.5K thats probably the engines knocksensor doing its job and the engine going back-forwd pulling-adding timming. Tune for more fuel and then up the boost checking the AF.
My 2Cts..!
My 2Cts..!
you have 200lbs on us. now, as to what the power output on the stage2 kits comes out too will determine it. if you break the 210hp mark or the 225ft/lb mark yeah, you will probably beat an stock srt. however, it would totally be a drivers race, because it at this point traction, drag, gear ratios, etc will come into play. the srt is a FWD true, but its built to be a high hp fwd car, meaning it has equal length driveshafts allowing a harder launch and less torque steer, factory LSD for better traction, etc. it would be a drivers race totally.
whomever gets a full 3" exhaust system will be in the lead!
My 2Cts..!
My 2Cts..!
and with the graph looking so rough....they did not do any smoothing to the graph at all.....thats normal for all cars....just eveywhere u get a dyno done they smooth the graph out so there easier to read..
i know gurudel stage 2 turbo on "auto" made 227whp. thats like 250-260 crank hp, srt has 240 crank hp. and is 200lbs more.
well anyway.. when i get my turbo which will be soon ill give you guys a huge update, and do it daily.
Originally Posted by Lancerguy'03
have u even been in a turbo stage2 lancer?? then how can u compare.....and stage 2 for our cars is running like 11psi....
btw i just walked a G35 the other day.....300hp or so arnt they??
i walked a G35 on I-1 (i think it was I-1, in cali going from L.A. to San Fran) in my nearly stock lancer cuz the guy couldn't drive and got scared at corners, soooo
btw, all those who are quoting hp #'s for the srt from the dealer should go on an srt forum and look at what guys are putting down stock....surprise, but it's a lot higher than what the dealer quotes....
not trying to hate on the lancer, i LOVE my car, just trying to keep things in perspective is all
I have a dyno date tomorrow morning. 3 pulls on a dynojet for 75bucks. SO ENOUGH ASSUMING. I'll post the numbers up first thing tomorrow. You can see my mods in my profile. I'm currently running 5.8psi with NO boost/exhaust/waskegate leaks.
funny how i raced an srt off a 20 mph roll he had i think just an exhaust and we were pretty much even untill around 60mph then i took him by like 4 car lenghts..imo stock srts are over rated now bigger turbo and more boost in an srt4 is a totally different story
there was somthing definatley wrong with his car or driving ability...and i doubt it was driving because it doesnt take much to shift!!! and would be willing to bet that it was only a catback, because a full exhaust system adds 15+hp on an srt, putting them at 245hp at more than 275ft/lbs of torque. that in a 2900lb car gets up and moves pretty easily
no offense bud, but from a roll, the srt is pretty darn fast (its their 0-60 times that hurt them). what kind of dyno numbers are you running?
i havent dynoed my car yet but it pulls, OT i was reading on the srt and there turbos run around 1800 and produce 450 whp......makes me want to sell my lan and buy an srt4(even though i think they look horrible)
