Last Stop.....Turbo Mandifold
Old Feb 18, 2006 | 05:56 AM
mightymitsuu's Avatar
Question Last Stop.....Turbo Mandifold
Hey Everyone im building my own Turbo kit everything is ready to go but im haveing problems with finding a Turbo madifold with a mate that will fit a 14B or 16G and will allow me to use an External waste Gate for my "03" Lancer 4G94 so far every were ive looked they want to sell u the whole kit any help or a finger in the right direction we help a great deal
Thanks
Old Feb 18, 2006 | 06:18 AM
impetus19's Avatar
Well you may want to look into buying a manifold for an eclipse and having a shop weld on a flange for the 4g94.. You can find eclipse manifolds on ebay that are already set up for an external wastegate.
Old Feb 18, 2006 | 07:36 AM
HobieKopek's Avatar
Are our runners spaced the same as an Eclipse?
Old Feb 18, 2006 | 03:36 PM
DJ.Kickz's Avatar
will the RPW manifold and downpipe work with a 16G and an external waistgate?
Old Feb 21, 2006 | 07:25 PM
N1te's Avatar
You can buy an evo manifold off ebay that is set up for a 16G for 2xx something if I believe. Then just take it to a shop and have them weld a lancer flange on instead of the evo flange. Bam you have a 16G turbo manifold for a lancer. I'm not sure if they have a place for an external wastegate or not though
Old Mar 10, 2006 | 08:29 AM
blaze_125's Avatar
Why not just get a turbo manifold from the 4g93(Mirage)? No shop adjustement required. Just bolts right on. Same flange, same exhaust ports.
Old Mar 10, 2006 | 03:43 PM
01G_WRX_02's Avatar
the runners arent to far off its only the out side ones from what i have read. get this flange and weld it onto the eclipse manifold http://www.cnfxperformance.com/produ...38e343420613f2
Old Mar 11, 2006 | 09:37 AM
SLVROZ_03's Avatar
Heard that the Evo turbo headers won't work well; the runners are spaced farther apart. Use a Mirage header as mentioned. The 4G92/93 I believe should be perfect; you'll just need to weld on a lancer flange.
Old Mar 11, 2006 | 01:39 PM
blaze_125's Avatar
4g93 uses the same flange. Direclt bolt-on
Old Mar 11, 2006 | 04:54 PM
01G_WRX_02's Avatar
where do you find the mirage turbo header??
Old Mar 11, 2006 | 07:57 PM
blaze_125's Avatar
mirage boards mainly.
Old Mar 11, 2006 | 08:01 PM
ozrally0303's Avatar
can somone post alink up of there best or most memebers board thanks
Old Mar 13, 2006 | 07:08 AM
blaze_125's Avatar
http://www.mirageforums.net/
whispering eye
Jul 14, 2012 09:07 AM
Tanman1986
11
Jul 27, 2010 12:54 PM
caLi4G63
12
Aug 4, 2008 08:36 AM
Gruppe-S
16
Apr 28, 2008 07:11 PM
Gruppe-S
31
Apr 8, 2008 11:58 AM
