Need help! Pic request! Anyone with EVO IC/Turbo help me!
Old Jun 1, 2006 | 07:01 PM
MK3Design's Avatar
Hey, Ive just recieved in my EVO8 Turbo, IC, IC Piping. I am close to being done with my kit.
I have my bumper off last weekend and put the IC up there just to get a feel how it would fit. It seems like the bumper support is in the way of where the intercooler has to go. Or is there room to mount the IC infront of the bumper support?
I also looked at routing the lower IC piping, every which way I tried to put it, it always seemed to be in the way of somthing.
So... Does anyone happen to have any pics of there lancer with the EVO IC/Lower IC piping without the bumper on so I can take a look at how its mounted and how the piping is routed?
Its a 2006 BTW incase the might have made any changes in this yr?
Thanks alot!
Old Jun 1, 2006 | 07:15 PM
civilrage's Avatar
ive seen the piping work on the 2-3 lancer.. but i dunno bout 4-6.....
ill see if i can get a pick of the 2-3
Old Jun 1, 2006 | 07:30 PM
Sicktght311's Avatar
Strange enough, i'm having fitment issues with the evo piping too, but i have an 03. I got the piping from the turbo outlet to the intercooler inlet to bolt up perfect to stock holes, however i cant seem to get the lower outlet to line up. i'm gonna take the bumper off again on sunday and see if i can get some more progress. Good luck!
Old Jun 2, 2006 | 10:36 AM
Blacksheepdj's Avatar
No offense, but why is that strange? You're putting parts from a car onto a completely different car. I'm amazed you got anything to bolt up. Different car, different motor, etc...
Old Jun 2, 2006 | 01:37 PM
Not strange per se, but i've just heard other people havent really had any problems with stuff lining up, oh well. Nothing a little inginuity and 2.25 exhaust bends cant handle
Old Jun 2, 2006 | 02:02 PM
Wallesasuaz's Avatar
some pics i found...
Old Jun 2, 2006 | 02:06 PM
OH this is even Better check this thread
https://www.evolutionm.net/forums/sh...ght=turbo+pics
Old Jun 12, 2006 | 06:15 PM
Dr Crash's Avatar
evo ic piping does in fact fit (i just did a test fit of my ic and piping last weekend). in order for it to fit perfectly with no modifications you need to relocate the battery and change to the evo style rad overflow jug and windshield washer reservoir. then just cut a couple holes in the black plastic panels (2 vertical ones) that run under the engine and bumper.
blacksheep, saying that it's a COMPLETELY different car and engine isn't very accurate. in piecing my 16g setup together and checking out suspension, body, etc, i have found things that are common between the two cars. like the i/c for instance; the lancer comes with the holes and threads for mounting it since we have the same rad supports. which also happens to be the reason why we can swap an entire front end in (bumper, headlights, hood and fenders inclusive). as soon as i receive some more parts i will find if some suspension pieces work as well.
the problem we have is that no one has tried before, or they have tried a full engine swap or something big and ppl believe nothing can be done.
Old Jun 12, 2006 | 06:30 PM
ozrally0303's Avatar
it will fit u just gotta f with it a lil trust me its on my car
bsh
Jun 16, 2017 05:43 AM
i64X
Evo X How Tos / Installations
138
Feb 27, 2016 03:30 PM
High_PSI
Oct 31, 2010 09:01 PM
dD Spikey
24
Oct 18, 2009 08:06 AM
SicLanEvo
Apr 15, 2008 10:12 PM
