crank sensor
Old Aug 12, 2006 | 05:41 PM
ryant25bb's Avatar
crank sensor
anyone have a pic of the crank sensor or a description of were it is. usually there right of the crank pulley right.
Old Aug 12, 2006 | 05:55 PM
LetItBreath's Avatar
From: City O Sin, MA...the not so sinish part though...
If your looking at the crank gear its at about the 2:00 position, plastic black thing with a thin wheel that runs through it.
Old Aug 12, 2006 | 06:41 PM
Synthrocker's Avatar
Location.
In depth view
Its billed as about an hour and a half job.
Old Aug 13, 2006 | 05:39 AM
ryant25bb's Avatar
im just going to clean it out. Mabye some water messed up the sensor. Would that show up if you got the codes pulled?
Old Aug 13, 2006 | 09:42 AM
Yes, why do you think its a crank sensor?
Usually when its bad it wont start, very rarly when a crank sensor is bad it will start. Could be the cause though, doubt it.
Havent got it scanned yet?
Old Aug 13, 2006 | 11:00 AM
ryant25bb's Avatar
No im going to try today, or just buy the tool $150.00. i just don't want it to stall on the way down there because it's pretty far from were i live. i guess before i do anything else i should get it scanned.
Old Aug 13, 2006 | 11:01 AM
ryant25bb's Avatar
I just heard if a crank sensor had a bad connection it may run rough. Although i never heard that before but im running out of ideas.
Old Aug 14, 2006 | 06:37 AM
airlinevomitbag's Avatar
http://www.harborfreight.com/cpi/cta...emnumber=94168
OBDII Scanner for cheap
Old Aug 14, 2006 | 08:13 AM
Myszkewicz's Avatar
Synthrocker's pic isn't showing for me, so here's a different one.
Old Aug 14, 2006 | 05:43 PM
ryant25bb's Avatar
thanks.
