EVO8 fuel pump??
Old Oct 15, 2006 | 06:55 PM
01G_WRX_02's Avatar
EVO8 fuel pump??
would it be a direct fit into my 02 OZ?? Im collecting parts for my turbo project and I wanted to know it if i could use it instead of a walbro??
Old Oct 16, 2006 | 12:56 PM
rhyzin's Avatar
yeah. check the how-to section for fuel pump install notes. not quite direct but you won't need anything extra.
Old Oct 16, 2006 | 01:02 PM
deffro's Avatar
I'll sell you mine if you want it. pm me
Old Oct 16, 2006 | 04:10 PM
01G_WRX_02's Avatar
All I found was this https://www.evolutionm.net/forums/sh...ad.php?t=22987
is the gsx fuel pump the same as a EVOs??
So I wont run lean running a Evo pump and FMU?? whant size is the evo pump anyway??
Old Oct 16, 2006 | 05:22 PM
Blacksheepdj's Avatar
GSX pump will work fine. Hard as hell to get in, but I got it to work.
Stock Evo8 pump is 160 lph.
Walbro bumps that up to 255 lph.
Old Oct 16, 2006 | 06:07 PM
01G_WRX_02's Avatar
still never got my Q answered??
So I wont run lean running a Evo pump and FMU?? will it support turbo on an OZ??
Old Oct 16, 2006 | 06:31 PM
rhyzin's Avatar
what ratio fmu are you gonna use?
Old Oct 16, 2006 | 06:41 PM
01G_WRX_02's Avatar
12:1 With evo 16g and Im tring to get a RRM piggyback with there big 16g map on it for there big16g kit. But does RRM even use a FMU with that kit??
Old Oct 16, 2006 | 06:46 PM
rhyzin's Avatar
oh yeah, how much boost are your running? fuel delivery will be proportional so this is important.
and no, the rrm 16g kit does not use a fmu. it uses an extra injector.
Old Oct 16, 2006 | 07:20 PM
01G_WRX_02's Avatar
Ic, ill be running intecooler 5-7psi at the most for now. Is it safe then to use just an FMU and no piggyback for now??or is that a big risk of the motor letting go? cause ive heard of people using them, but IIRC I also heard it runs ****ty like that. So whats the deal?? Im trying to keep this as cheap as possible. But I will upgrade with a RRM piggyback in the summer.
Old Oct 16, 2006 | 07:54 PM
rhyzin's Avatar
i'd just say spend the extra $40-50 and get a walbro 255 for $100. it's peace of mind if you want to run a fmu. i'm going to say some people have problems, and some people don't.
if you were to run the evo pump, you'd need to get larger injectors to insure proper fuel delivery. the reason for that is fuel pressure. the more psi of fuel pressure you try to extract from the pump, the less overall fuel(in liters/hour) it can deliver.
so here's a quick comparo. evo fuel system runs 4 550cc injectors at 50 psi(i think). magic 8 ball says that if the injector duty cycle was at 100%(which is never recommended), the pump would have to flow 141ltr/hr. as it's rated at 160 ltr/hr at 43psi. roughly the 140 ltr/hr @ 50 psi.
take a lancer fuel system with 4 240cc injectors at 100 psi, assuming this is where the fuel pump maxes out. magic 8 ball says that this will want 87 ltr/hr. i don't see this happening as the evo pump will run only 63 litr/hr @ 73 psi.
BUT, this is based on the assumption that the evo get's the shoddy 12.6 volts to the pump from crappy wiring like the rest of us instead of 14v which i've read in some places it does. if it does get the full 14v, then it *might* cut it as it's rated at 112 ltr/hr @ 73 psi in this case. that might barely make it at the 100 psi mark. then you'd have to invest in a fuel pump rewire kit. blah.
moral of the story, spend the extra money on a pump you know will supply the extra fuel
https://www.evolutionm.net/forums/sh...d.php?t=106930
Old Oct 16, 2006 | 08:04 PM
01G_WRX_02's Avatar
yeah I thinking the Evo pump wouldnt be able to put out the high pressure the FMU will make.
I just wondering what kind of problems do people have with FMUs?? besides them failing some times. Has anyone on here actually blown there motor on here??
BTW what do the RRM T-28 kits use for fuel management?? I know the t25 kit uses and FMU anone have problem with that kit?
Old Oct 16, 2006 | 08:08 PM
rhyzin's Avatar
not too sure about blown motors, but i've seen complaints of just failing or people running lean on boost. i personally don't trust a fuel system running that much pressure. an extra injector, to me, seems better than this.
Old Oct 16, 2006 | 08:14 PM
01G_WRX_02's Avatar
I wonder if I could buy the stuff right from RRM to use the 5th injector and control unit for it. anyone know if can??
Old Oct 16, 2006 | 08:22 PM
rhyzin's Avatar
they don't like breaking up their kits so you can probably ask and special order stuff. it's a bit expensive.
