maintaining a turbo
Old Jan 18, 2007 | 01:53 PM
ROCK's Avatar
Retork turbo related bolts
periodically do oil changes 3 to 5K (use whatever oil you want but oil pump has trouble with synthetic so I don't tempt fate!)
Monitor oil, water, hose integrity etc a little more often than N/A. Don't be afraid to touch hoses and get a little dirty. The under hood temps are a lot higher too so things like hoses may get old faster especially the little vacuum type hoses. Check IC piping clamps too every once in while. Still it is not much to do if you did a proper install and it is worth it! Some other threads up here boast of guys with our kits running over 70000 miles on the kits. Have fun boosting and just follow the recipe for sucess.
ROAD/RACE
Old Jan 20, 2007 | 09:50 PM
Elvis's Avatar
as far as the oil thing goes. i'd follow the suggestions of the pros. the guys who develop turbos for this car. they'd know best ya know.
Old Jan 24, 2007 | 05:01 PM
ROCK's Avatar
I can't prove sythetic suck for Lancer but we have built motors from scratch and we have seen the oil pump and compared to other Mitsu pumps. It is hard for Lancer pump to pull the thinner oil.
ROAD/RACE
Old Jan 24, 2007 | 06:15 PM
Elvis's Avatar
could one replace the oil pump with a better one in order to take advantage of the benefits of synthetic oil. or does the cost not add up. hmmmmm
Old Jan 24, 2007 | 06:21 PM
mitsuozboi's Avatar
So the waldbro 255 fuel pump doesnt like synthetic oil? or the stock oil pump doesnt like syn? dont you guys (RRM) use the waldbro in your kit?
Old Jan 24, 2007 | 06:23 PM
ambystom01's Avatar
The walbro is a fuel pump, it has nothing to do with the oil system.
Old Jan 24, 2007 | 06:24 PM
ambystom01's Avatar
Oops, double post.
Old Jan 24, 2007 | 07:20 PM
Elvis's Avatar
right, but still, is it a walbro that comes in the rrm kit. sorry just curious.
Old Jan 24, 2007 | 07:27 PM
ambystom01's Avatar
Yeah but its a fuel pump, it has nothing do with the oil problem.
Old Jan 24, 2007 | 08:06 PM
ROCK's Avatar
Just use cheaper oil! DONE and DONE.
ROAD/RACE
Old Jan 25, 2007 | 05:55 AM
iyi0521's Avatar
I thought i heard that RRM was pushing the use of Royal Purple?
Old Jan 25, 2007 | 06:13 AM
Lancerguy'03's Avatar
no, ive used Castol 20-50w oil in my car and have had no issues boosting for 40,000 miles. done compression checks, looked at plugs everything was good. i would just use the non-syn oil like RRM says. bottom line
or we can not listen to RRM...cause they havent done any research on Lancers at all....
Old Jan 26, 2007 | 08:30 AM
jakermeister's Avatar
I have a question. Does your turbo need to spool down before you turn your car off? I heard if you don't let it spool down it could mess up the engine.
Old Jan 26, 2007 | 08:54 AM
ROCK's Avatar
IT spools down along with thengine idle no? What people prolly mean is t hat the it helps to remove the super heated oil from the turbo. Good to run the car for 30 sec or 2 minutes before turning it off. Hence a turbo timer.
Good question though Jaker!
ROAD/RACE
