Fan wiring
Old May 11, 2007 | 11:28 AM
XAlliedYouthX's Avatar
Fan wiring
Well I got my fan installed on the car but I'm not sure about the wiring. I know what wires go where but should I cut off the plug coming from the car and attach it there or should I should it be put on after that black box thing that originally split off to the 2 stock fans?
Old May 13, 2007 | 10:40 PM
Nobody?
Old May 15, 2007 | 10:44 AM
iyi0521's Avatar
After the box as that is the relay for the fans.
Old May 15, 2007 | 11:47 AM
I figured it was the relay for the different speed settings for the fan but I also didn't want to leave anything there that I didn't need to. Any recommendations on where to mount it to since the original fan assembly is out?
Old May 15, 2007 | 11:55 AM
kungfugirl's Avatar
did u remove both fan assemblies, with the o3 arent they one peice? did u just replace the one in front of the header? or did you change the one by the tranny too?
Old May 15, 2007 | 11:57 AM
Yeah its one big assembly. I took out the entire thing and replaced it with a 12" high speed slim fan mounted on the opposite side of where the stock one was.
Old May 15, 2007 | 12:04 PM
kungfugirl's Avatar
so ur gonna take the relay box, and mount it and then wire the fans after that. not sure where u can mount it though.
Old May 15, 2007 | 12:08 PM
Thats the part I'm trying to figure out now. There really isn't anything close enough that I can find to mount it to. I need to find out where the RRM kits say to mount it to.
Old May 15, 2007 | 05:41 PM
kungfugirl's Avatar
usually they say cut your assembly in half and leave the side in that has the box on it.
that side does not get in the way of their up down pipes.
Old May 17, 2007 | 10:50 AM
iyi0521's Avatar
my fan assembly came apart no prob and i have an '02 so i shouldnt be much different.
Allied just give me your number. Your like 20min from me. Ill come down and help ya.
Old May 17, 2007 | 10:52 AM
I have stock one already out and the aftermarket one in. I'm just trying to figure out where to mount the relay now.
Old Jun 28, 2007 | 09:25 PM
lancerrally45's Avatar
where is the best place to get a 12'' slim fan?
Alchem1st
Mar 15, 2022 08:47 AM
foxbear2277
Aug 16, 2012 05:09 PM
Thebigjoke1337
Aug 18, 2011 10:28 PM
98autogstspyder
45
May 16, 2009 12:23 AM
MrB
May 23, 2006 04:24 PM
