installing EGT need help despertly
lost the derections what do i hook the wires two i have a orenge
yellow red ,blackand, white
befor drilling and tapping the hole should i remove the turbo so n shaving go throughand wheer should i drill it search but only found info on evos thanks alot
yes, pull out the pipe to where ever you are going to tap into, you dont want any shavings going into your motor or turbo...
Not sure on the wiring, which EGT did you get?
http://www.racingknowledge.org/topic.asp?TOPIC_ID=1011
Here's is something about EGT and tuning. Some people may not agree with the author's premise of his research.
I know it has helped me big time understanding how to tune TC cars. It's not even that hard tuning by knock count via datalogger.
