Max boost with Evo 16G setup???
Old Sep 6, 2007 | 12:13 PM
SLVROZ_03's Avatar
Might I just say, you really can't say at a certain psi is the breaking pt...better yet, use a hp rating instead. BTW, have you had the car dyno'd? What you running? Install those 440's NOW! LOL
Old Sep 6, 2007 | 12:37 PM
dmoney1988's Avatar
All this turbo talk is getting me excited
Old Sep 6, 2007 | 01:33 PM
senate6268's Avatar
Originally Posted by Shingen
Post pics of that scoop when you install it... I was thinking about doing the same thing only putting the scoop over the intake.
The CF vent I got from CarbonTrix is like 10" x 13" I think. I was also contemplating the idea of running a smaller vent for the intake also, but it's not highest priority on my list. I need to go pick up some rivets so I can maybe get around to installing it this weekend.
Old Sep 6, 2007 | 01:38 PM
senate6268's Avatar
Never had my car dyno'd and I don't really plan on it. If I had to guess I'd say I'm probably between 210whp and 230whp. I know that I'll have better numbers once I swap my 440cc injectors in. My stock injectors are running 100% on IDC. The only real comparison I can give for power #'s is beating an '07 Civic Si with Greddy catback and Injen cold air by like 5 or 6 cars and still pulling away. My friend was not too happy with me on that race cause I told him I was still running 5psi!
Old Sep 17, 2007 | 12:16 PM
senate6268's Avatar
Car's still running strong at 11psi. After installing the 440cc injectors I'm not worried anymore about popping an injector running at over 100% IDC. On a site note, I've been using the graphing function in EvoScan to graph my logs and guess at my power and torque. Every log has given me a consistent ~250-260hp and ~260-275ft/lb torque!!! I'm not sure what the correction % with this function is compared to a real dyno or how accurate it even is, but perhaps it's a start. I do plan on taking my car to get it dyno'd in the near future. A shop just opened up closer to my house that has an in-house dyno so here I come. I'll keep everyone updated on what progresses. Also, I would recommend everyone taking a look at my thread on my busted oil pressure fittings. I would hate to see this happen to someone else. Cheers!
Old Sep 17, 2007 | 12:24 PM
ambystom01's Avatar
Nicely done, get it dynoed though, bench racing is just silly.
Old Sep 17, 2007 | 12:29 PM
senate6268's Avatar
No worries. The more and more I drive my car the more curious I am getting to know how much power she really has now. I need stiffer springs in the rear because the front lifts up slightly on acceleration. I have a set of Evo VIII springs I've been meaning to install.
Old Mar 27, 2008 | 05:21 PM
Complink's Avatar
senate did you ever take your car to the dyno? are you still running 11psi?
Old Mar 27, 2008 | 05:28 PM
senate6268's Avatar
I went back in October or November. Here was the results I posted:
https://www.evolutionm.net/forums/sh...d.php?t=305489
I'm still running around about 11psi on my kit. I'm currently transitioning over to a T3 Super 60 setup with a ram horn manifold, new intercooler and all new piping. The Megan Racing manifold everyone uses (including me) for their setups is junk. The welds on mine cracked so bad that one of the runners actually broke off from the 4-1 weld by the turbo flange. I'll be on my new setup by the end of April. I should be going this weekend for the new intercooler and cold side intercooler piping install. I had a small aluminum radiator installed a couple of weeks ago and it freed up a ton of space in front of the exhaust manifold.
Old Mar 27, 2008 | 06:21 PM
ihearthondas's Avatar
Ooh, I've been looking for a half-rad for a while now. Where did you get yours and who makes it? I'm looking to do that and a battery relocate in the near future to save space. I wanna see you current engine bay
Old Mar 27, 2008 | 07:42 PM
senate6268's Avatar
Yea I did a battery relocate to my trunk with a Moroso box and wiring kit. I went the AMS way with my half radiator setup. I took a radiator for a 92-00 Civic, had both necks replaced with 1.375" necks and had the bottom neck relocated to center. That's pretty much what they do for their Evo small radiator setup. I had the shop that's doing my turbo kit do the fab work.
Old Mar 30, 2008 | 08:50 AM
darkmitsu's Avatar
nice senate... you must have a sick car... wish you were closer to raleigh nc, i would like to come see it in person.
R/TErnie
80
Jan 7, 2021 02:46 PM
Alchem1st
Jul 28, 2017 01:15 PM
JosRacing4G94T
May 3, 2017 10:58 AM
Lanart2011
34
Mar 22, 2016 11:50 AM
Diavlo
34
Oct 4, 2007 05:09 AM
