project "Road Rage"
Old Feb 11, 2008 | 04:07 PM
SLVROZ_03's Avatar
Well, pry it apart...might just have a good seal to it. You did take the shaft out right?
Old Feb 11, 2008 | 04:15 PM
senate6268's Avatar
Originally Posted by dibsen
OK. How do I seperate the hot side of the turbo from the chra? I took off the band holding the two parts together but it won't budge.
There is a large snap ring that needs to be removed to separate them.
Old Feb 12, 2008 | 05:30 AM
dibsen's Avatar
The cold side has the snap ring. The only thing I can see that is holding the hot side to the chra is a large cirular clamp. I will post up some pics so you guys can see what I am talking about.
I have not removed the shaft. I didn't know I had to.
Old Feb 12, 2008 | 05:56 AM
dibsen's Avatar
my wife took my keys and my camera to work today. I swear if she could fit the computer in her purse she'd take that too.
Old Feb 12, 2008 | 01:44 PM
SLVROZ_03's Avatar
Okay, I re-thought it over in my head...you "probably" won't have to remove the shaft/turbines. But I thought in your pass post that you already had that snap ring off? LOL Go to Sears and get a good pair of snap ring pliers...and not the ones I got that you have to attach the various sizes of points. Get the set of three with different sizes built in or don't detach. Just take off that snap ring and the clamp on the other size and you should be set! have you thought about rebuilding it with it all taken apart?
Old Feb 14, 2008 | 08:00 AM
dibsen's Avatar
Here is a pic of it all taken apart and painted. Yes I will rebuild it and polish the cold side housing.
Old Feb 14, 2008 | 08:04 AM
dibsen's Avatar
the snap ring your talking about is on the cold side. There is a small pin on the hot side that keeps it from rotating. I put the turbo in a vice and used a hammer to knock it loose.
Old May 1, 2008 | 09:30 PM
dibsen's Avatar
I am moving to jolly old England and will Not be finishing the project.
The turbo and mani will be up for sale for whoever is interested.
rage mang
Dec 11, 2013 03:45 AM
iel322
16
Jun 6, 2008 03:23 PM
drumgod
Jan 8, 2004 09:04 AM
