My turbo set-up
Take her apart and make sure spring is set. Also, did the thing have a valve seat that went int between the wastegate and the pipe?
A guy here had that issue, and ended up selling the kit cuz he was retarded and couldn't figure out why he was slow
As I recall, yes there was. I mean, I did pull good numbers through more then 10 pulls. Something happened after that, while cruzing home.
I'll open the top of the wastegate once I get home.
The dump pipe will exhale exhaust when it passes through the wastegate. The wastegate should not be opening at idle otherwise you will not allow your turbo to build any boost at any RPM or throttle position. Your wastegate is not working for some reason.
BTW, here is the dyno sheet. Please don't mind the rpm. For some reason it showed wrong rpm. Tune was done all the way to 6800rpm. A/F is not showing but it's low 11s because of the high compression.
Torque could have been even higher but we pulled alot of timing.
Below are my old NA numbers, lol. I only gained more than 100 torque to the wheels, lol.
206/223
206/223
The Tial 38mm might. You should take your Turbosmart one off and go to some shops to compare dimensions and locations of the inlet and outlet with other wastegates.
