Oil Restrictor
Old Jan 3, 2008 | 10:47 AM
Mirage2.0's Avatar
Oil Restrictor
Do you guys are running one? I know that every BB turbo should have one.
I'm seeing too much oil in my 300zx t25 turbo, but I think that my return line is too small. Brand new turbo and smoking.
Old Jan 3, 2008 | 10:48 AM
Markley02's Avatar
All I know is that oil feed lines are tiny and return lines are huge. lol.
Old Jan 3, 2008 | 11:31 AM
cincy's Avatar
all turbos should have a restrictor with either -3 or -4 feed lines and -10 or -12 return lines.
Old Jan 3, 2008 | 01:06 PM
senate6268's Avatar
Cincy's spot on. Most of our oil feed lines are -3AN and the return lines are 5/8" which is roughly -12AN, I think. Mitsubishi turbos do not require a restrictor. Only ball bearing turbos need them.
Old Jan 3, 2008 | 01:20 PM
cincy's Avatar
it depends on the inlet fitting used. A garrett t3t4 still gets a oil restrictor but many stock turbos you banjo fittings to regulate oil flow
Old Jan 3, 2008 | 01:26 PM
SLVROZ_03's Avatar
My friend is using a lever-type restrictor on his SC-61 Civic build. But yes, it's a good idea to run one!
EvO_essence
14
Jun 21, 2016 11:47 PM
jrmav32
21
Mar 15, 2009 05:29 AM
Timebombxxx99
Mar 12, 2009 08:44 PM
Timebombxxx99
Mar 1, 2009 11:34 AM
GgreyEVOIX
Nov 20, 2006 04:31 PM
