injector
Old Mar 18, 2008 | 10:31 AM
  #31
ambystom01's Avatar
Useless posts removed, if you want to bicker, take it to PMs.
Old Jul 3, 2008 | 07:03 PM
  #32
rakillah's Avatar
275cc injectors
If you would like to use the 275cc Denso style injectors instead of the Stock Bosch 240cc injectors, you can use them. I got mine off a 1995 Galant 2.4l 4g64 engine. They are High Impedence injectors, injector code INP-065. You will need the wiring harness for all for injectors and wire them to your harness. If you do get the injectors, just like many of denso type, you will need longer fuel rail bolts about one inch longer than stock, if you go to the junkyard to get them make sure you take the galant fuel rail bolts too cuz they work perfectly instead of going to Lowes or Home Depot to do some guess work just to strip up the mounting holes. I just installed mine last weekend and i will tell you that all though they are 275cc you will notice the difference in power available compared to the stock 240cc. This will put you in the range of about 220 to 230 hp with some kind of mindful tuning. Also the 275cc injectors of the Galant are great because of the type of nozzle it employs, it uses the Pintle style injection, just look inside the bottom of the injector, instead of the Bosch disc type the stock injectors use.
