16g benchmark map
go to the engine management/ tuning forum If your looking for a "modified" map that someone is using to run their 16g setup you could ask someone to post a screen shot of their fuel map. I should tell you that under no circumstances should you just copy all the values into yours and assume it will run well or at all... There are many variables that factor into the amount of fuel you have going to each cylinder(ex: intake manifold, ported head, upgraded fuel injectors, fmu, fuel pump, more/less airflow due to piping sizes etc...). Not to mention the timing side of things... Try to list your mods also when you ask so someone who maybe has similar ones can help you out. good luck!
ok so i got my fuel shortage worked out... i put an 8:1 fmu on it but its still running a tad bit lean, about 12.7-13.3 at wot, with maxed out fuel maps and stock injectors. I ordered a recalibration kit for the fmu to make it 12:1 so that should fix things until i get injectors. I'm hitting about 8-9 psi at 4200rpm and it gradually falls to about 6-7psi. i have a speedo vid in my sig. oh and im auto so don't hate
94AWDcoupe
Dec 31, 2003 08:55 AM
