Alky injection.
Old Aug 1, 2008 | 11:55 AM
smartidiot2122's Avatar
Alky injection.
Does anybody here use alky injection? I have a friend with a Spec V and they can run a good bit more boost with it.
Old Aug 1, 2008 | 03:22 PM
cincy's Avatar
Unless you can raise timing or boost, not really going to gain you much but a slightly colder charge
Old Aug 1, 2008 | 03:48 PM
ambystom01's Avatar
^Exactly, people don't generally run meth or water injection until they actually reach a point where they either A. want to literally max out their turbo (like a guy in our club running a TD04 at 20+ PSI) or B. can't get the numbers they want on pump gas.
Old Aug 11, 2008 | 09:13 AM
Mirage2.0's Avatar
^totally not true. With my high compression and water/meth injection went from 7psi (204whp/220torque) to 10psi (247whp/255torque) without aggresive timing. My intake manifold and head was freaken frozen. Best thing I ever got for my mirage. My tires would brake loose in 3rd on azenis.
Lots of tuning was done tomy whip.
P.S. Too bad that one night stupid mbc spiked on me to about 15psi, and 2 rods went through my block. Ohh well, will have to build another block.
Here is my old vid with only 7psi. No new vids sorry. Watch it in high quality, looks alot better, lol.
http://www.youtube.com/watch?v=OCuNzZGU1so
Old Aug 11, 2008 | 09:45 AM
ambystom01's Avatar
Yours is clearly a fairly hardcore setup, if he's running stock compression (albeit with upgraded pistons and rods), there's no point in spending the money on meth when you can just turn up the boost more (assuming the turbo isn't out of its efficiency range).
Old Aug 11, 2008 | 09:55 AM
depsy's Avatar
is it worth running meth if you do have a upgraded pistons and rods, im about upgrade mine and would like to know if this is worth it.
Old Aug 11, 2008 | 10:30 AM
Mirage2.0's Avatar
True, but you can run it so your intake temp. would be much cooler. I just wanted to use it more for safety issues. It it gives you so much more. Again, you have to get to the dyno.
Old Aug 14, 2008 | 03:21 PM
yeah i think im just gonna save my money for a better car, lancers suck.
Old Aug 16, 2008 | 09:40 PM
cincy's Avatar
You unlike most here have the ability to both increase boost and timing. Without access to either of those or ability to hold the power, w/m is only good for cooling intake temps which a good core will do since people are barely making any heat at all with only 5-7psi on turbos made to run 1-2bar or pressure
scheides
10
Jul 3, 2009 08:20 AM
boomn29
28
Feb 14, 2007 10:29 AM
Blue Evo 8
27
Jul 12, 2006 02:03 PM
marks03evo
55
Mar 27, 2006 08:52 AM
mobounce
Jul 12, 2005 11:28 PM
