Finally Starting to Build
Old Aug 6, 2008 | 05:08 PM
drucea's Avatar
Awesome. What manifold did are you going to be using? Also for the resistors on the fuel injectors, do I put one inline with each of the 2 wires going to the spark plugs, or does just one need it (will I need 4 or 8 resistors)? Thanks again for the help.
Old Aug 6, 2008 | 05:25 PM
ThunderOZ's Avatar
all stock evo stuff right now pretty much.
Old Aug 6, 2008 | 05:42 PM
drucea's Avatar
Also, does anyone know about GodSpeed wastegates? I've heard their intercoolers are good. Would anyone trust their wastgate?
Old Aug 6, 2008 | 06:54 PM
drucea's Avatar
Also I just noticed there is no port on the compressor side of the turbo to run a line from the wastegate to. Can that port be anywhere in the intercooler side piping, or am I missing something?
Old Aug 6, 2008 | 07:37 PM
senate6268's Avatar
This line to the wastegate need only be on the pressurized side of the turbo. It can be anywhere between the turbo and throttle body.
Old Aug 6, 2008 | 07:47 PM
doctorjon's Avatar
You don't need to external the wastegate unless your turbo doesn't have it internally. And i remember reading your turbo has a internal wastegate. Don't worry about it unless your manifold needs a external manifold i would suggest on buying a turbo without a internal wastegate. If you already have the turbo thats internal, grab the manifold that has the external hole shut. I mean your not looking for lots of power so internal is cool. My turbo is internal and its been good. You can use both in one but you would need to weld the internal hole shut to prevent leaking.
Old Aug 6, 2008 | 07:52 PM
drucea's Avatar
Well the internal gate is 10 psi and thats more than I want to run.
Old Aug 7, 2008 | 10:30 AM
Ozturbo's Avatar
One thing you might want to consider, I am not sure it applies to you, but when I put new injectors in my car it wouldn't run until i tuned it, too much fuel.
Old Aug 7, 2008 | 10:35 AM
drucea's Avatar
Yeah i was wondering about that. I might start with just the fuel pump. Then the bored rail, then the injectors depending on what it needs at the moment. Thanks
Old Aug 7, 2008 | 11:30 AM
Complink's Avatar
well with a fmu and stock injectors you should be fine at 7psi until you get it tuned with bigger injectors. just make sure your watching your afr's.
Old Aug 7, 2008 | 11:32 AM
Complink's Avatar
also i have a 03 auto piggy with software if your interested
Old Aug 7, 2008 | 11:52 AM
drucea's Avatar
Is the piggy for a turbo? How much do you want for it?
Old Aug 7, 2008 | 12:06 PM
Complink's Avatar
pm sent
Old Aug 7, 2008 | 03:31 PM
doctorjon's Avatar
boost controller my friend
Old Aug 7, 2008 | 04:12 PM
ambystom01's Avatar
If the wastegate is 10 PSI, I don't think you can go any lower than that.
