Depsy's custom t3/t4 build
A simple ball and spring mbc would allow the turbo to spool up faster and it would also help hold the psi longer which should keep the 230whp hold all the way to redline.
^ I know what the stock redline is. He is using a much larger turbo and when he gets to the point where he is going to run a considerable amount of psi on it, he will need atleast another 500rpms to make the most out of it.
Then there is no reason with better boost control that you shouldnt be holding 10psi till past 7k. Get a mbc and you will be pleasently surprised. YOu will however need a lower psi spring to run it.
