What do you recommend on cooling fan?
Old Nov 17, 2008 | 05:14 PM
*02Lancer*'s Avatar
I am going to be installing a turbo as soon as possible on my 02 lancer. i know from looking and reading in this forum that the second fan i beleave the AC fan will have to be removed.so i was wondering what CFM does the stock fan's produce? what CFM and fan are you other turbo guy's running, if you are running one? does anyone know the stock amp(current) draw. i want to try to get a fan as close to stock as possible.
Old Nov 17, 2008 | 07:07 PM
doctorjon's Avatar
Your t25 turbo is small that it doesn't even need to be removed. I am running a t25 turbo. Your A/C and A/C fan can stay. Thats if you want it.
Old Nov 17, 2008 | 07:08 PM
doctorjon's Avatar
And i forgot to mention that it will just need to be removed during installation of course.
Old Nov 17, 2008 | 07:52 PM
*02Lancer*'s Avatar
o sweet what turbo manifold are you using?
Old Nov 17, 2008 | 08:22 PM
doctorjon's Avatar
its a 4g93/4g94 turbo manifold.
doctorjon's Avatar
This my whole kit.
Old Nov 17, 2008 | 08:44 PM
*02Lancer*'s Avatar
wow nice looking kit were it come from u have a build thread i tried to search but couldnt find it. what brand is the mani?/kit
Old Nov 17, 2008 | 09:08 PM
doctorjon's Avatar
I have no build thread. My camera was stolen shortly after my install. So i couldn't post up any pictures. My whole build is just that of this turbo kit. A RRM test-pipe and a N1 style 2.5 catback exhaust from ebay. The manifold can be bought from this website >http://www.importperformanceparts.ne...man-mitsu.html
They are the same manifolds that come with the kits that are sold on Turbokits.com and Turbo Specialties
I have the turbo kit manual also.
Old Nov 17, 2008 | 09:19 PM
*02Lancer*'s Avatar
thank you very much how long have you been boosted? and what type of psi are you running? look's pretty much like the kit im peacing together one step at a time? you remember how much you payed for that? and what does it do for fuel other then the fpr, was the rest up to you to do like pump and tunning?
Old Nov 17, 2008 | 09:24 PM
doctorjon's Avatar
I guess you can since June 08. I got lets say a very good deal on this turbo kit used. It was probably a miracle. I've been running strong at 7psi daily boost. Sometimes i just stay out of boost. Well you can add 2 injectors to run more gas and of course make more power. I decided to keep it off since gas prices had been going up. I have yet to do a tune for the turbo. Still saving up money and with the holidays rolling up i'll have to do my tune sometime next year. Look into that turbo specialties website it should explain everything with fuel management.
Old Nov 17, 2008 | 09:30 PM
*02Lancer*'s Avatar
ya thanks for that site it will come in handy to bad they dont sell pieces of the kit apart instead of the hole kit
Old Nov 18, 2008 | 10:31 PM
ThunderOZ's Avatar
I'm curious about this too. I have some parts I wanted to return to advanced auto but don't have the receipt, so I was just going to swap out for a fan...
Old Dec 2, 2008 | 08:00 PM
senate6268's Avatar
Run a pusher in front of the radiator on the passenger side and a puller on the radiator in the engine bay on the driver side instead of the dual stock fan setup. Anything higher than 800-900cfm should be more than adequate for the fans.
Old Dec 3, 2008 | 01:33 AM
ThunderOZ's Avatar
Ok I'm just running one on pusher on the passenger side until spring. So would a puller on the driverside work better than a pusher on the radiator?
Old Dec 3, 2008 | 02:41 PM
senate6268's Avatar
Both function as well as the other. Since the temps are much colder for a few months you'll be fine. I'm running a small aluminum radiator with a puller fan in the engine bay and see constant 180* temps all day long.
