recommended turbo timer?
Old Sep 26, 2003 | 08:51 AM
HobieKopek's Avatar
Install it yourself and you'll spend all of a half hour if you're literate.
Old Sep 26, 2003 | 09:17 AM
Kontradictions's Avatar
I have the GReddy auto timer and install took me about 1 minute. There is a harness you can get that fits the 2nd gen eclipse and it plugs right into your ignition, very simple install. It's a great unit and it has tons of features.
Old Sep 26, 2003 | 09:20 AM
mobius97's Avatar
A minute yeah right!!! And I had the harness. I had to hardwires mine to the ECU and E brake took a little over an hour...had to take apart the center console and working with hardwiring on the ECU is something that should never be rushed.
Old Sep 26, 2003 | 10:02 AM
TURBOit's Avatar
i did it last week, seriously shouldnt take an hour for lancer, you have 5 screws in total, the hardest part for me was removing the original harness into the sterring column, was a pain, splicing into the e-brake is easy, get a wire tap in, my timer actually came with one, all you need is a screw driver, a pair of pliers, and your hands to do this job
Old Sep 26, 2003 | 10:30 AM
mobius97's Avatar
So on the ;ancer you dont have to tie them into the ECU huh? Then I would see it taking no more than 30mins to install. I had to solder some connections to the ECU harness for my application.
Old Sep 26, 2003 | 10:39 AM
TURBOit's Avatar
nah on the lancer, you plug the stock harness into an eclipse turbo timer harness, then the turbo timer harness into the slot
Old Sep 26, 2003 | 10:43 AM
Jiggbobo's Avatar
get the new blitz dtt dc2 type x tt it has a built in digital boost gauge. wish i had waited for it
HobieKopek's Avatar
I found two wires in the harness(according to the diagram) were actually swapped (blue and green I believe...primary and secondary ignition) but made no difference whatsoever in function. I swapped them just to keep things consistent. Make sure you get a clean tap on the e-brake wire. Mine didn't break the sheathing on the wire when I used the clampy plastic splice thing included with my FATT DCII. Problem solved when I opened it up and saw this. Clean, easy and handy install.
Old Sep 26, 2003 | 10:46 AM
TURBOit's Avatar
how do you know if theres a problem with the e-brake tap?
Old Sep 26, 2003 | 10:47 AM
HobieKopek's Avatar
When you turn the car off it'll shut off instead of keeping the car running.
Old Sep 26, 2003 | 10:49 AM
mobius97's Avatar
Man that is one long name for a timer!
Old Sep 26, 2003 | 10:51 AM
HobieKopek's Avatar
Um...aren't the Type X and DC II separate products?
http://www.blitz-na.com/turbotimer.html
Old Sep 26, 2003 | 10:59 AM
LMBLF8's Avatar
The Blitz and GReddy TT's are the easiest and most reliable turbotimers in my opinion.
Old Sep 26, 2003 | 11:22 AM
TURBOit's Avatar
my blitz says DC III
Old Sep 26, 2003 | 11:35 AM
revhappy's Avatar
I know about the HKS and Blitz, but what are the other features on the Greddy (and APEXI and any others for that matter).
