what fuel do you use?
Old Jan 29, 2009 | 02:30 PM
ThunderOZ's Avatar
Oh so disregarding gas mileage, gas with ethanol is better?
Old Jan 29, 2009 | 03:10 PM
4g94T's Avatar
yes, ethanol has great resistance to knock.
thats why people switch over to e85.
i cant wait for a closer station to open up in my city.
i'd like to see the difference in power
Old Jan 29, 2009 | 03:13 PM
ambystom01's Avatar
Well there's some debate as to whether gas with ethanol is better than gas without ethanol.
Old Jan 29, 2009 | 03:15 PM
4g94T's Avatar
regular gas vs e85?
or regular gas vs gas + 10% mix?
Old Jan 29, 2009 | 03:16 PM
ambystom01's Avatar
What I mean is regular gas of X octane vs. blended gas of X octane.
Old Jan 29, 2009 | 03:20 PM
4g94T's Avatar
oh i see what you mean.
well the highest regular gas cali people get is 91
so e85 is an easier alternative for us because its available at stations rather than storing race fuel
Old Jan 29, 2009 | 03:52 PM
BrandonShaw's Avatar
Shell V-Power, 93 Octane, i'm running N/A, but I still like to think i'm doing
everything I can to take good care of my engine.
Old Jan 29, 2009 | 03:57 PM
ambystom01's Avatar
Then stop running higher octane than you need.
Old Jan 29, 2009 | 04:05 PM
how is running fuel with slightly more octane bad for my engine?
Old Jan 29, 2009 | 04:08 PM
ambystom01's Avatar
Your car can't use it so the fuel isn't fully burned.
Old Jan 29, 2009 | 05:42 PM
ThunderOZ's Avatar
Are you running a piggy back or something that messes with the ecu on the car? If you were then I would understand you running premium gas.
Old Jan 29, 2009 | 07:56 PM
Jonas's Avatar
DUDE Screw that... just run 87 I do it alll the time and I notice no difference... =P
Old Jan 29, 2009 | 08:00 PM
SilverShadow03's Avatar
I fuel up with Unocal 76 Premium 91 in CA.
**OOPS...this is the Lancer forum....anyways...this is what I use in my Evo 8.
Old Feb 2, 2009 | 10:20 AM
BlackOperative's Avatar
Originally Posted by ambystom01
Higher octane has more knock or detonation protection and burns slower. This is why running high octane if you're not tuned for it can be bad, you don't fully burn the gas and take advantage it. Ideally you want to run the lowest octane you can without getting knock. If you're not getting any knock on 91, running 94, 101, 110, etc. is just pissing money away.
Ambystom is right. A higher Octane is harder to burn, so even if you were tuned for 110, if your not on a track all the time under boost ALL THE TIME, gas mileage is gonna suck on the highway and in town, because you are not burning all the gas. And, if you have to then try to pass emmisions, HC's are going to be through the roof.... My motorcycle MUST burn 91, but it only requires that rating when above about 9,000RPMs. I myself did an emmisions test and HC's at idle were 2700! Ideally the number should be about 200 or less with a bike. At 9,000 revs the number drops to about 400, and the bike revs to over 14,000. So, its somewhat the same with boost.... How often are you under boost? Ambystom is absolutely correct to say that you should try to use the lowest possible octane rating while still eliminating knock. This will give you te best milege and even power, because you are now burning all of the gas, not half of it. The lower the number, the higher the heat, and heat makes power. So if you can use it, 91 is probably going to be the best and safest for your car.
Old Feb 2, 2009 | 10:26 AM
Originally Posted by JRR
theres like 4 or 5 e85 stations in the greater madison area around here. thanks for the advise on the sonoco stuff. i currently have it tuned for 93 at 7lbs.and it works great. never tried shell gas, but there is a sinclair station in middleton wisconsin that sells 100% pure gas no ethanol added. anyone think that as premium would be better than the bp im currently running.
o the 93 also helps when your morning temperature is -25 degrees!
Actually a lower octane rating is going to start better at lower temps. A higher octane rating is less volitile, meaning it is harder to vaporize. If it can't be vaporized, you are injecting pure liquid gasoline into your engine, and liquid gas DOES NOT BURN. So a lower number is going to start better. I've lived in ND most of my life, so I know what its like.
