random misfire help
Old Mar 26, 2009 | 09:07 PM
Demon_ni2's Avatar
hrmm.. maybe im misreading.. but r u sure its misfire and not blow-out(just wondering because i get blow-out sometimes when i let off the gas and get back on it jsut because of where im at in the rpms and crossover, but under normal throttle or full trottle i dont get it at all).... why do you have a 5th injector setup on an 02(thought only ralliarts used that)?
Old Mar 27, 2009 | 08:53 AM
ryant25bb's Avatar
mabye you misread or i mistyped jonas but yea mine is pretty much only at wot sometimes not but more at wot,like on the freeway last night at wot in 5th gear it would misfire every couple sec like it was hitting revlimiter then i would let off and get back on it and it would be ok for a split sec and then misfie again??
Old Mar 27, 2009 | 02:22 PM
Jonas's Avatar
yes that is exactly whats happening... so do you guys know the fix? will a good tune fix it?
Old Mar 27, 2009 | 02:39 PM
4g94T's Avatar
these are the spark plugs i use:
http://stores.speedcorps.com/-strse-...ugs/Detail.bok
they're already gapped to spec.
Old Mar 27, 2009 | 04:40 PM
Demon_ni2's Avatar
k.. hate to say it.. but its the plugs(or might be, mine didnt work and i had those to). try your stock plugs and gap them to .030
see if that fixxes the problem.
Old Jul 8, 2009 | 09:14 PM
MurphDurph's Avatar
so based on these facts, its 99% the plugs? fyi im throwing the same code and experiecing the same things
Old Jul 19, 2009 | 09:51 AM
MurphDurph's Avatar
bump!!
pullin the p0300 code, runnin custom 16g turbo @ 7 psi, 8.8:1 wiseco pistons
need help plz!
n3m3sis
17
Feb 12, 2014 11:17 AM
hoof hearted
38
May 1, 2013 03:15 PM
Arkitek
18
Jun 27, 2010 06:53 AM
vr4play350
14
Mar 13, 2009 12:19 AM
shadow1
Aug 11, 2007 09:00 AM
