Turbo Problems
Old Apr 6, 2009 | 08:45 PM
  #31
OZ Rally's Avatar
My injectors weren't 100% in the Manifold, they were hanging a little higher.
I fixed them and double checked every line then fired it up.
CEL did come on after 30 or so miles of driving. I'm going to pull the code tomorrow, probably running a little lean.
Old Apr 6, 2009 | 09:17 PM
  #32
lilazn64's Avatar
You won't get a CEL without driving it a bit. But as it was mentioned previously. You do need to connect those two valves on the intake manifold. My car would die when I would try to pull that hose and pour seafoam into it.
Old Apr 7, 2009 | 10:41 AM
  #33
Green_Bandit's Avatar
That sounds like an exhaust leak of some sort. Are you sure everything from the manifold under is tight?
Also, you should plug up those holes on the IM. Just get a smaller hose and you can plug it with the same line. Its comes stock like that.
Old Apr 7, 2009 | 04:43 PM
  #34
senate6268's Avatar
When you install injectors it is good practice to take a dab of motor oil and spread it around the upper and lower rubber seals before seating them. Helps to prevent issues like this.
Old Apr 7, 2009 | 04:47 PM
  #35
OZ Rally's Avatar
Yea that is a good idea.
I pulled the codes today and I'm running lean in bank one. Is it a good idea to run the 460cc injectors or will I be running too rich and ruin my plugs?
Old Apr 9, 2009 | 12:07 PM
  #36
doctorjon's Avatar
How's the car running now? You should be able to just keep your iridiums. Do you know if you have a rising rate FMU?
Old Apr 9, 2009 | 12:08 PM
  #37
doctorjon's Avatar
I meant and run stock injectors. I've been running with just a FMU and I've been fine.
Old Apr 9, 2009 | 02:22 PM
  #38
Lean bank 1 is the first O2 sensor IIRC.
The code goes bank 1 or 2. Bank 1 would be in the first four cylinders (since we only have 4 its obvious) then the next number would also be a 1 or 2 depending on which O2 is reading this code
Old Apr 9, 2009 | 04:15 PM
  #39
OZ Rally's Avatar
Car is running good, just need to wait for the polyurethane to dry on my front motor mount.
I also had a misfire but that was because the spark plug wires were damaged.
I have the usual leaks here and there but I got those fixed. Time to save up money for a wideband and a tune.
Old Apr 9, 2009 | 05:41 PM
  #40
lol you arent the only one!
Old Apr 9, 2009 | 06:07 PM
  #41
senate6268's Avatar
My brother has 2 brand new AEM UEGO widebands he never got a chance to install in his 350z that he's looking to sell. Also, if you want we can meet somewhere and I'll give your ECU a simple tune with EcuFlash. Where are you at in Illinois? PM me.
Old Apr 9, 2009 | 06:30 PM
  #42
OZ Rally's Avatar
PM'd
Oh and hopefully it's a free ecuflash. Lol
Old May 2, 2009 | 11:04 AM
  #43
Chameleonzero's Avatar
does your bov recirculate or vta and were exactly is you maf sensor at on the car
Brandon Robblee
Sep 8, 2015 09:44 AM
tyler734
Jul 14, 2015 12:03 AM
evo_production
Apr 29, 2014 01:54 PM
EEVOH
14
Oct 12, 2013 09:08 AM
Arkitek
18
Jun 27, 2010 06:53 AM
