clutch kit for turbo application?
Old Nov 29, 2009 | 06:53 AM
GTS08's Avatar
Question clutch kit for turbo application?
Im wondering if there is a clutch kit for a lancer turbo 2008? Im planning to mount my kit this Christmas and Im wondering if there is one cause down here in Puerto Rico one of our turbo lancers blow up the clutch getting almost to 300WHP can anyone help me ? Im planning to brake that barrier with some friend of mine who is also planning to do the same this with his lancer
Old Nov 29, 2009 | 09:58 AM
yitzac1990's Avatar
get an ACT
MR1-HDG6 kit
https://www.evolutionm.net/forums/la...-clutch-d.html
and good luck breaking 300!
Old Nov 29, 2009 | 01:56 PM
GTS08's Avatar
Originally Posted by yitzac1990
get an ACT
MR1-HDG6 kit
dude thanks a lot Ill try on that one !! thanks for the support !!! even better than the support I got down here hahah !!
Old Dec 10, 2009 | 04:17 AM
hiramabif's Avatar
guys, when you turboed your lancer, did you change the Fuel pump? if yes, what pump did you used? and for the injectors as well?
Old Dec 16, 2009 | 07:49 PM
yitzac1990's Avatar
stock EvoX fuel pump, Bosch 480cc injectors
Old Dec 17, 2009 | 11:03 AM
09_Lancer_GTS's Avatar
i have... stock fuel pump and stock injectors plus 5th injector for boost
Old Dec 18, 2009 | 12:37 AM
hiramabif's Avatar
how much is the output(hp) did you change our exhaust pipe? what is the cc of the additional injector? thanks
Old Dec 18, 2009 | 12:38 AM
hiramabif's Avatar
how much is the output(hp) did you change your exhaust pipe? what is the cc of the additional injector? thanks
Old Dec 18, 2009 | 09:18 AM
280 to crank i believe, i just have an axle back right now, and i believe the cc is 1000
dbouch
Feb 13, 2015 09:48 AM
Mar__io
Aug 30, 2013 12:11 PM
GTS08
Aug 30, 2008 06:52 PM
AznFlip
17
May 18, 2005 07:09 AM
LancerTuner2005
23
Feb 13, 2005 12:04 AM
