Lancer 08-10 Turbo? need help?
Hahahahahaha
wow dude no need to be (right)dick lol when you asked what it was tuned with, I (assumed) thought you meant what aftermarket piggy back or something like that was I using(??wtf??), so I answered and said it was a custom dyno tune. apparently you dont know what a dyno tune is(apparently i do & wasnt satisfied with the generic response) , because when anyone says "hey I got a custom dyno tune", it usually means(they dont know what they have) a tuner tuned my car for me on the dyno, using whatever software he/she uses. you should have asked (no)"What software did your tuner use?" then i would have given you a straight up answer like I did to EngRWW33. im not trying to hide any info man, why would I want to see another lancer blow their motor(engine, bro)? ive already been there and back and it wasnt fun! i told you a got a custom dyno tune, how is that hiding anything? also, what does my sig have to do with any of this? im not bragging, just stating that i was the first xtremeboost turboed lancer, and what my HP numbers were. I assume (quit assuming so much it causes ****
) that you think every single person on here with a mod list and HP numbers is a complete bragger?
if so, you have just made a lot of enemies...
also, I am going turbo again this summer, but what does me not being turboed have to do with it either? are you one of those people that believes if someone doesnt physically have something in their hands, then they know nothing about it?more assumptions
yes it was tuned on a dynojet dyno in Orlando FL, in about 80 degree weather. the dynamometer color was black, and Jestr tuned it. he used a Tactrix USB cable that lit up when being used and OpenECU software, ECUFlash to be specific I believe, ran on a Dell laptop that he carries around in a backpack. I think i was wearing a black shirt and shorts with my red Rob Dyrdek DC shoes, and Jestr was probably wearing a light colored shirt, maybe white or grey. the Dyno sheet was printed in grayscale on a Dell desktop computer. that was just the first tune, want the second tune scenario so you know what went on there? nice memory but someone
this gi
if so, you have just made a lot of enemies...also, I am going turbo again this summer, but what does me not being turboed have to do with it either? are you one of those people that believes if someone doesnt physically have something in their hands, then they know nothing about it?more assumptions
this giEvolved Member
does your car keep going into limp mode? mine did that. idk how your intake is setup, but when I was turboed, we had to switch to a 3" intake instead of 2.5" so the velocity of air was lower (higher volume) and the MAF sensor cant be too close to the filter.
haha thanks for editing my original post for me! whats the difference between a motor and an engine, bro?
yes!! yes !!! i aving the same problem!!It revs only up to 4,000 RPM! and the chek engine light goes on thanks to GOD you heard me ok the MAF sensor is close to the filter because I have a custom pipe ( the one from the turbo to the MAF housing) then he MAF housing is welded to the pipe ( an ultimate racing intake) and then the filter is about 3inches away from the filter do you think that could be the problem ?
I was using the stock lancer MAF, and im pretty sure it has to be at least about 4 inches after the filter in the piping. my total intake pipe length was almost 3 ft, went from the turbo, up like the RRM one, and then curved over towards the driver side. yes, i had to relocate my battery.
hey i got your message, but for some reason i cant respond! so here I go lol
hey fellas I am trying to turbo my lancer rite now and having an issue I have a piggyback aem fic and the car is running but when we drive it the car wont get passed 4000 rpm. even at full throttle it wont do anything. Any advise with be greatly appreciated
my friend thats called limp mode and it depends on the way you fixd you kit , check in all the vacum lines and everything see the maf sensor if it works correctly, then try to relocate he maf sensor in that case remember the maf messes things up when you go turbo because of the difference of the air flow try to relocate the maf exactly as the oem model hope it works good luck
. & i have already talked to your tuner & guy from extreme boost. they seem to be helping my brother some we'll see........... haven't been on in a while.
lol
