Big turbo problem
Old Nov 9, 2003 | 07:51 PM
TURBOit's Avatar
yea def, doesnt sound liek too bad of damage, but jsut that the line was securely on there, you might want ot get the pipes rewrapped, your pistons should be fine, the connection must be faulty thats all i can think of
Old Nov 9, 2003 | 08:21 PM
LancerO-Z's Avatar
I agree with Turboit, sounds like a bad connection on the return line. Maybe it wasn't tightened enough, or it could have had stripped threads on either the male or female end. Hard to say. I've had my RRM kit in since March and I had only one problem, my wastegate bolts loosened up a bit, so I went out and got some better lock washers and tightened the bolts down with a prudence. No problems since. I run 6 lbs, and I drive my car daily and I have no problems with underhood melting so far. I am, however, going to get the EVO style carbon fiber hood just to be safe when I get my tax return.
I hope you get everything fixed man. Good luck.
Old Nov 9, 2003 | 08:55 PM
TURBOit's Avatar
dont forget theres al ot of things made for heat reduction ont he market, i always post this link because i believe they are the best and most thorough company on the subject:
http://www.designengineering.com/
Old Nov 9, 2003 | 09:34 PM
HobieKopek's Avatar
Where did you run the oil line? Mine popped twice (in 3 days no less) because of the engine torquing and tugging too hard on it. Ended up getting 2 oil changes and some new SS hose.
Run it as close to the block as possible without it getting in the way of things, and make there there isn't TOO much slack (but enough for the motor to shift on heavy throttle). I dunno if it's the only problem or even a problem at all, but it may help. Best of luck.
Old Nov 9, 2003 | 09:53 PM
TURBOit's Avatar
yea hobies got a point, i forgot about that, the engine shakes like it wants to break loose
Old Nov 10, 2003 | 06:53 AM
Mitsubishi_03's Avatar
Try and Get Them Pics Up
Old Nov 10, 2003 | 09:01 AM
jamie's Avatar
just put my turbo on saturday by saturday night the car doesn't run.i hit full boost in first then when i shifted to second the car just lost power and died. it will start idles bad and i heard metal to metal contact. i am taking it to a shop to see how bad i messed it up. it is not road races fault i should have let a shop put it on and check all the vitals berfore i got on it.i put about 100miles on it that day using 20w 50 vri oil 93 octane with nos octane boost there was no warning temp was fine no smoking everything seemed perfect and the power was crazy. i did notice alot of lag you could hear the turbo start to spool about 3000 rpm but the car didn't start to pull till 4000 rpm and when the wastgate opens up it sounds awesome. iwill keep everybody posted on what the problem is
Old Nov 10, 2003 | 09:38 AM
HobieKopek's Avatar
You should really start your own thread when you have different problems like that. $5 says you're rebuilding your engine if you keep the car.
Oh, either that or your compressor surged due to a problem with BoV (shifting at full boost) and your turbo is looks like a Cuisine Art. In that case you'd be lucky if parts of the compressor didn't make it into your engine.
Old Nov 10, 2003 | 10:14 AM
TURBOit's Avatar
also he said he used NOS OCTANE BOOST, BAD IDEA BRO, that sucks, look at spending a couple grand to get it fixed, an engine rebuild is usually about 5,000
Old Nov 10, 2003 | 10:24 AM
HobieKopek's Avatar
Boosting octane shouldn't be a problem. It's just detonation prevention unless there's some other weird additives in it.
Old Nov 10, 2003 | 10:27 AM
TURBOit's Avatar
either that or the blow off valve / wastegate wasnt installed properly and he boosted way too high
Old Nov 10, 2003 | 10:35 AM
HobieKopek's Avatar
Yup. That's what I think. (The BoV)
Old Nov 10, 2003 | 10:59 AM
jamie's Avatar
when i first ran the car down the road i had a fuel line come off,don't ask. drove the car about two or three miles had no power due to no fuel pressure caused the car to run very lean.after the fuel line was fixed plenty of power. but the damage had already happened to the piston to running the car lean so say bye bye to the piston. by the way the car still runs so new forged pistons a little bit of labor and back to haveing fun.at the most 1500 to 2000 dollars.
Old Nov 10, 2003 | 11:04 AM
TURBOit's Avatar
well id say your lucky, but if you ran lean that means you heated it up, you might want to check your head, do a compression test to see if its the piston or vavle, if you dont know hwo to do it, go to a shop and ask them to do it, they can tell you by dropping oil into the cylinder to see if compression goes up or down (piston or valve) the onyl reason i say this is because i don't believe you could ruin a piston and still be operating the car, i GUESS if it only occured to one piston you might be able to operate, but if it was on two or more your looking at a significant loss of compression
Old Nov 10, 2003 | 11:46 AM
jamie's Avatar
as soon as you start the car it idle rough then after about 15 to 20 seconds you start to hear tapping sound that is when i turn off the car so it doesn't do any more damage. i hope it is only the piston or maybe a valve also the car has over 50,000 miles on it and hits red line daily, so i imagine the pistons or valves already had some wear to them. i will let you know as soon as i know.i don't think it had any thing to do with the bov or wastegate.
